Water Pump Leak on WR 426
2 replies to this topic
  • hoellc
Posted March 05, 2007 - 07:40 PM
As a brand new owner of an 02 wr 426 I was wondering if anyone else has had this issue. I have noticed that when I start my bike there is a very slight coolant leak coming from the water pump cover. It's just a drop or two and actually seems to go away when the bike heats up and everything expands. Has anyone else had this issue and if so what's the fix? I figure just a gasket or O-ring or whatever seal it uses. Any advice would be appreciated.
  • clark4131
Posted March 06, 2007 - 06:14 AM
You need to change out the water pump shaft and seals. The part numbers for the 450 are in the FAQ. Cross reference them to see if they match...SC
  • hoellc
Posted March 06, 2007 - 10:31 AM
Thanks for the info, I'll check it out.
