DR.D help!
5 replies to this topic
  • CaseyWR450
Posted March 03, 2007 - 04:54 PM
So It's time to repack my DR.D silencer now and can't get the screws out of it. I got one out, broke one off, and rounded one off, then quit. Any ideas on how to get the screws out. :applause: Oh and they are loctited in there.
  • Toyuki
Posted March 03, 2007 - 05:09 PM
r they counter sunk (flush) or r they button head, screws? if you have a steady hand you can drill them out in the center and ez out them. other than that I would have to see them, next time give it a little tighten before you back them out, it breaks the loctite free!
  • CaseyWR450
Posted March 03, 2007 - 05:23 PM
They are not counter sunk and they have allen heads on them.
  • Tough Guy
Posted March 03, 2007 - 09:12 PM
Can you get a hold of the allen heads with vise-grips? If not you'll have to drill them out carefully...
Chris
  • CJ06WR
Posted March 03, 2007 - 10:06 PM
Before you use the vise grips try and spray some WD-40 or other penetrating oil on the alleb bolts. Hopefully this will help loosen the little bastards up a bit. Then wipe the head of the allen bolt clean so you can get a good hold with the vise grips. If this doesn't work, you can either drill them out or take it to a machine shop and for a small fee they will do this for you. Good luck!
  • Fullbore4
Posted March 03, 2007 - 11:42 PM
good points ......another is to lock a small vice grip on whats left and then apply heat with a butane torch to the screw while applying torque to see if it'll break free.
