Oil filter - Stainless or regular?
9 replies to this topic
  • 99yz400
Posted March 02, 2007 - 06:57 PM
Hey Guys,
I'd like to know if it is worth it to buy a stainless steel filter??
Would it clean the oil more efficiently than a standard oil filter?
If so, do you have any recommendations (Brands + Models)?
Thanks a lot:ride:
  • 99yz400
Posted March 02, 2007 - 07:00 PM
I forgot, I have another question. Is there a particular type of coolant to use for radiators? I heard that some bikes tend to overheat so I'd like to get the best coolant possible. Any tips or suggestions?
Thanks again
  • 250Thumpher
Posted March 02, 2007 - 07:29 PM
I used a Scotts SS filter. I have used a CRT and it fell apart about a year after cleaning...
You get better flow? How do I know this? Well, my YZF used to have the notorious grabby clutch, using a brass filter. With using the same oil, I just put in a Scotts. The grabby clutch immediatly went away. Since drilling the clutch boss removes the grabby clutch (improved oil flow) this is leading me to believe that these filters flow more oil. Same story on my 06.
It has a larger surface area than a paper or brass filter. This means you are able to handle more debris, and you get the larger flow rate.
You also filter better than paper or brass. Paper may have large holes in it.
Paper may also bypass the oil when the oil is cold. A scott's is less likely to because of the improved flow.
Not only that, the filter pays off in just 12 oil changes. If you change your oil twice a month (oil filter every month then) 6-12 months the filter would have payed off for itself.
For coolant, I use engine ice. It comes premixed and does reduce temps. If you do not choose this route, go to Safeway or a food store and buy some Distilled Water. It does not contain any minerals that will clog up your system.
  • Captaincautious7
Posted March 02, 2007 - 07:39 PM
I used the Scotts through 2 crfs and many oil changes before buying my yzf. I purchased the Ready Racing Brand for it because it was cheaper and I believe it filters just as well. Either way you can't go wrong with a stainless compared to stock paper. You'll save a significant amount of money.
Posted March 02, 2007 - 10:09 PM
Hey Guys,
Thanks a lot:ride:
Yes.
In a way, yes. It's a little complicated, but overall, IMO, yes.
Scotts. Unquestionably.
  • 99yz400
Posted March 03, 2007 - 06:50 AM
Ok, thanks, I'll probably buy a Scott filter.
How do you clean it when it's time for oil change?
Do you have to use a special cleaner or you could use carb cleaner, for example?
Thanks again
  • King_Air
Posted March 03, 2007 - 07:22 AM
I use carb cleaner. I spray from the inside out.
  • 250Thumpher
Posted March 03, 2007 - 07:46 AM
Carb cleaner sprayed inside > out, then to the sink with warm water and dishwashing soap, then I put the top opening right at the outlet of the nozzle, and let water flow full blast through the filter. After all the soap is gone, I take it to the aircompressor where I blow out the water.
I do this every oil change. It's free, why not?
Posted March 03, 2007 - 12:00 PM
You can clean them with almost anything that will remove oil, as already mentioned. If using water, a good follow up is carb cleaner, since most of them contain alcohol of one kind or other, and that absorbs water.
The key is to remember that the inside of the filter is where the clean oil lives. If you happen to leave some tiny particle on the outside by mistake, it won't really matter, but you should try to keep all debris out of the interior while you clean it.
  • 99yz400
Posted March 03, 2007 - 03:29 PM
thanks guys, I really appreciate your comments! :applause:
I think I'll buy one of those Scott filter.
  • 5 replies
  • Hot  38 replies
  • Hot  50 replies
