Will YZ450 03 Cams fit in 01 WR426
6 replies to this topic
  • Max_Aus
Posted February 27, 2007 - 01:01 AM
Hi I have an 01 WR426 and am able to get hotter cams at the right price, standard cams are overpriced, I want to have auto decomp for easier starting but was wondering in all the wisdom here will the following YZ cams work ok as I can not get WR426 cams at the moment:
YZ450 03 - 05 intake = 8.9mm lift and 269 deg duration
WR426 01 - 02 intake = 9mm lift and 265 deg duration
YZ450 03 - 05 exhasut = 8.7mm lift and 269 deg duration
WR426 01 - 02 exhaust = 9mm lift and 265 deg duration
So can I replace just the Exhaust Cam to get auto decomp or should I replace both intake and exhaust cams so they match.
  • jbrooks26
Posted February 27, 2007 - 01:37 AM
You can replace the exhaust cam by itself if all you want is the auto decomp. However, you will realize your best power increase if you replace both cams. Do a search on this and you will find about 3 weeks worth of reading on the subject. Hope this helps.
  • Max_Aus
Posted February 27, 2007 - 02:03 AM
Thanks Josh, I was just wondering about the lift and duration differences as they are not standard cams.
Looks like both will be the go.
Thanks mate.
  • jbrooks26
Posted February 27, 2007 - 11:20 AM
No problem, you may want to do some searching to see who has put both cams in an older head. I know that people who installed the exhaust cam only had to set their timing a little different. The marks would not line up properly so they had to count pins in the chain to get it set right. I don't know if this will be the case since you are installing both cams. You may want to PM grayracer513, he may be able to provide more insight on the project with both cams. Hope this helps.
  • simon@vic
Posted February 27, 2007 - 01:47 PM
just go for the EX cam.
  • byggd
Posted February 27, 2007 - 02:19 PM
That’s what I read too so I only replaced the ex cam on my 02. From what I understand the yz exhaust and wr intake cams complement each other by smoothing out the midrange hit the 01-02 are known for and pull harder on the top end. Here are a couple of links that might help.
  • Max_Aus
Posted February 27, 2007 - 06:29 PM
Hi All,
It looks like I go just the Exhaust cam as performance is not the priority only the auto decomp. Thanks for the advise and the link to the help files.
