06 YZ450 Cycra Probends
5 replies to this topic
  • brotherdallas
Posted February 26, 2007 - 05:59 PM
Cycra Probends - *triple clamp mount*... After replacing the stock bars with "Windham/Rm Highs," my handguards are running too low to be effective. I can run them through just one bolt on the triple clamp, but this is just a temp fix and not strong at all. Does anyone have any ideas for a solution?
-Thanks
  • GCannon
Posted February 27, 2007 - 09:21 AM
I had this problem when I installed my Scotts Sub Mount my bars became so high that the tripple clamp mounts pull the handguards down.
Try this: http://store.cycrara...m/uclhamos.html
or This: http://store.cycrara...rapawisomo.html Since I have the WR with the Endurance computer the Solution was not a good choice for me since it blocked the view of the computer.
  • klb130
Posted February 27, 2007 - 06:45 PM
I had a mounting problem with these on my 07 YZ450. Cycra sent me the bar mounts and it's a done deal. Use the bar mounts. They work fine.
  • brotherdallas
Posted February 28, 2007 - 10:47 AM
Thanks guys. I have a message into cycra for some bar mounts. I didn't really want to go that route cause the cockpit just feels more cluttered. Are those special bar mounts to work with existing triple clamp mounted probends or just regular probend bar mounts?
  • yz440e
Posted February 28, 2007 - 10:52 AM
the bar mounts utilize the barkbuster, not the TC mount piece. So when you install the bar mounts, you will have triple clamp mounts left over. All of cycras barkbusters are the same, the just use different mount systems.
  • NorCal
Posted February 28, 2007 - 11:30 AM
I'm not a fan of the triple clamp mounts at all. I don't want all the force of a fall to be exserted on my triple clamps/forks.
I have the Pastrana bend (probably similar to the Windham High) bars and found the regular bar mounts work perfectly. After all that hassle:bonk:
  • Hot  50 replies
  • Hot  36 replies
  • 0 replies
  • Hot  47 replies
  • Hot  113 replies
