bottom end bog on 06 YZF450
9 replies to this topic
  • Todd D
Posted February 26, 2007 - 05:00 PM
I just purchased an 06 YZF450 with a Dr. D pipe and it has a bog off the bottom when you crack the throttle. Dr. D recommends going to a 45 pilot and a richer needle (5TA194916LR00) with the needle in 4th position.
Before I go buying a bunch of jets I was hoping someone whoe recommend what they are using.
Thanks!
Todd
  • kyle450rider
Posted February 26, 2007 - 05:38 PM
the hot setup for the 07 is 170 main and a 48 pilot
Posted February 26, 2007 - 07:21 PM
45/165 with the stock NFPR in #4
Dr. D full SS system, '06 YZ450, sea level to 3500 feet.
  • Ga426owner
Posted February 27, 2007 - 08:22 AM
The 06 stock needle NFPR needs to be swapped to a NFLR - DRD recommends this. I did this and it does help. Also go with a 45 or 48 pj
Or send the carb to Zipty - they permanently fix the bog
Posted February 27, 2007 - 09:04 AM
The NFLR vs. the NFPR (stock needle) is not an enormous issue, even though it may be be just what you need. The two needle profiles are so close to the same that lowering changing from a stock NFPR (clip in 4) to an NFLR (clip in 4) is the same as lowering the needle half of one step.
  • RIDE 13
Posted March 04, 2007 - 03:54 PM
Im in wash. st about 500ft,I have white bros. E-2 170m/48p. I have know complaints about it
  • Baron Von Beard
Posted March 04, 2007 - 07:12 PM
I can't believe that you guys need such rich main jets. I'm running a 45 pilot 160 main and stock 06 needle on the 4th spot.
  • twenty34
Posted March 17, 2007 - 08:47 PM
I surprised you are running so lean. Have you checked your plug recently?
  • yam 3
Posted March 23, 2007 - 12:00 PM
Same bike same pipe 48/170 stock needle and position runs fine. Might be too rich, but this is my first 4 banger so I have a hard time determining if it is too rich or not. I have researched how to tell, but have not gotten a good answer. Not to hijack but how do you tell?
  • David Hopkins
Posted March 25, 2007 - 03:24 AM
try a boysen quickshot and rejetting mines a weapon now with the new micron exhaust system to, my local yamaha dealer did the jetting to suit the altitude were i live
  • Hot  36 replies
  • 10 replies
  • Hot  47 replies
  • Hot  28 replies
