Yamaha wr450 regulator/rectifier testing
6 replies to this topic
  • yamahahahahaha
Posted February 25, 2007 - 09:55 PM
Can anyone tell me how to connect a multimeter in order to test the Voltage regulator/rectifier on my WR450?
Problem I have is that the bulbs constantly blow when I increase the idle.
Cheers.
  • CRF45OX
Posted February 27, 2007 - 02:43 AM
shes ****ed, i had the same problem, i bought a new one from oem thumpertalk (heaps cheaper than locally) and havent had a problem since.
if you want to check - where your light plugs in - put the 2 meter leads across the 2 terminals and set it to ac volts (when u rev it, it will probably say about 28V and it should only be 12 - 14V. Remember.... AC not DC!
good luck mate
  • yamahahahahaha
Posted February 27, 2007 - 05:59 PM
Thanks for the reply. Shes definitely gooone. MM reading of 27v.
Thanks for the help.
  • MSHAM
Posted February 28, 2007 - 12:53 PM
I replaced mine with a Baja designs. I think my stock reg. is in a box in the garage. PM me and I'll look for it, if you want it!
  • ausgeflippt13
Posted February 28, 2007 - 02:52 PM
It's not ever the rectifier's fault (well, never say never...); it's almost always the fault of a bad ground. Regulator/rectifiers need a FANTASTIC ground in order to function well, and without it the current will pass thru the system unperturbed by the reg/rec.
I had my reg ground to the same place as my lights (underneath the seat on the frame) and after blowing a bulb upon testing, I realized the ground wasn't going to do. So, I moved it to a motor mount (for JUST the reg, nothing else should go there) and everything has worked peachy since. I had a choice of two reg's: the Yami brand one at $60 or the generic one used for Harleys (tells you something about harleys :applause: ) for a mere $12 or so.
It's all about grounding! :applause:
  • yamahahahahaha
Posted March 08, 2007 - 03:23 PM
Replaced the reg the other day and shes running sweet. I hear that the wr450regs can be a bit dodgy so I ll keep an eye on it.
Thanks for all help
  • AMG_Eric
Posted March 10, 2007 - 10:56 PM
baja designs replaced mine with a ktm one. no problems since. the yamaha ones are know to SUCK.
