Front wheel question
4 replies to this topic
  • shoboat90
Posted February 25, 2007 - 07:43 AM
Just noticed this morning that if I hold the front brake and press forward, the wheel moves back/forth just a tad...you can feel it. Do my wheel bearings just need to be repacked or do I have bigger problems? BTW...it's an '02 426.
thanks
jim
  • BuckHopkins
Posted February 25, 2007 - 07:53 AM
i had the same question.. mine was the floating brake caliper in the front, it moves a little bit, but not enough to affect anything.
  • new2blu
Posted February 25, 2007 - 08:23 AM
The "play" you are feeling is the way the front disc is made. It is made in 2 pieces 1 outside and 1 inside they are joined with round bushings--at these bushings there is a little bit of play; this is where the play is coming from. I experienced this quite a while ago and thought something was wrong also. No problems with your front disc this is normal.
  • Ga426owner
Posted February 25, 2007 - 08:44 AM
Wheel bearings need to be replaced when you get side to side movement from the entire wheel/tire
  • shoboat90
Posted February 25, 2007 - 08:47 AM
Thanks for the info guys. I don't have any side to side movement....so, hopefully I'm all good.
  • 10 replies
  • Hot  47 replies
  • Hot  36 replies
