Trail Tech XR650L Temp sensor install..
29 replies to this topic
  • trxxr
Posted February 24, 2007 - 05:22 PM
So I got the new air-cooled sensor for my Vapor. It WILL NOT fit under the sparkplug. So I checked to see where I could install it and found the oil line and installed it there. I checked the motor temp with an IR temp gun and they were only about 2 degrees diiferent. I think this will work good. Check out the pics..
http://www.putfile.c...hp?img=4850028]Posted Image
http://www.putfile.c...hp?img=4850026]Posted Image
  • CTXr650L
Posted February 24, 2007 - 07:41 PM
i would think if your temp readings are matching up well it would be a good spot, seems well protected and out of the way :applause: . take another ride and see if it shows the same as the ir gun under varying conditions.
  • Fingers
Posted February 25, 2007 - 03:33 AM
How/when did you get it? I've had a order in for 4 months and the trail-tech website has been down for quite a while, I'm starting to think they are having problems.
  • trxxr
Posted February 25, 2007 - 07:51 AM
I got it last week. They posted on here they were in stock so I called them and they sent me one FREE!! They said they were not putting people on a waiting list just to call them back every other week.
  • asf
Posted February 25, 2007 - 08:59 PM
I have the same issue on my R, you put it where the outer crush washer was on that oil line?
  • mikyrc
Posted February 26, 2007 - 02:47 AM
Good think to know!
I'll email them, hope they'll send me one to Spain too.:applause:
  • trxxr
Posted February 26, 2007 - 07:54 AM
It actually fit "around" the crush washer. So I kept it on and put the banjo bolt though it and put the stay back on there. It fits good there and is out of the way from stuff and the wind. Plus I think it will give a better temp reading there with the oil line and head.
  • Jeff@TheQuadShop
Posted February 26, 2007 - 10:04 AM
I can't tell exactly how it is mounted from your pictures and decription. Could you take a pic from a different angle so we can see it a bit better?
I'm getting ready to install mine tonight. :applause:
  • trxxr
Posted February 26, 2007 - 04:01 PM
Here is a better shot. I have the bike back together now.
http://www.putfile.c...hp?img=4867141]Posted Image
http://www.putfile.c...hp?img=4867140]Posted Image
Hope this helps some. Once you see the oil line and sensor it should click..:applause:
  • TrailTech
Posted February 26, 2007 - 06:30 PM
Sorry the CHT did not fit the spark plug.
What is the bolt diameter? 8mm?
Geoff@trailtech.net
  • trxxr
Posted February 26, 2007 - 06:48 PM
Well it does fit around the plug. But the head has no clearance for the sensor to fit in it's a tight fit. But this spot seems to work so far.
  • asf
Posted February 27, 2007 - 12:57 PM
Whats a good temp reading for normal conditions? What's the danger zone for the 600R (assuming the operating temp is the same as the L?)
  • Fishthumper
Posted February 28, 2007 - 07:24 AM
Do you have a e-mail adrress where i can buy this setup and also a front steel
braided brake line? for a XR-650L. Steve
  • asf
Posted March 06, 2007 - 11:00 AM
Can anyone help me out here?
Pleeeeeeeese!
  • machman
Posted October 05, 2007 - 08:31 PM
What size is the one you have, 10mm?
  • machman
Posted October 06, 2007 - 06:44 AM
I just went out and measured it with the calipers. The OD of the oil line brass crush washers are 13.5mm. I'll go with the 14mm temp sensor. It'll fit under the oil line (between it and the head), around the outside of the inner crush washer (because it's slightly larger), but still be tight against the head to get a good reading.
Thanks for all the help in this thread!:confused:
  • XR_Dude
Posted October 09, 2007 - 09:19 AM
I also recently installed the same computer on my 97 XR 600R. I mounted the temp probe on top of the head where the engine mount hanger bracket meets the head. I will relocate to the oil banjo fitting.
My problem is: I am not getting an engine temp indication, but the max temp indication is working. I connected the ground wire to the same frame ground that the other electrical components are connected to. Any ideas????:confused:
  • martinfan30
Posted October 09, 2007 - 10:13 AM
Pleeeeeeeese!
i cant give you exact but i used a infrared temp gun from snapon awhile ago after riding 20 miles on the hiway. i saw anywhere from 350-500 deg f. depending on where i pointed the gun. it was obviously hottest near the exhaust ports.
i would go out and get one and do some different riding scenarios then record the temps from the gun. this way you can get a good baseline for the temps you want.
  • mikyrc
Posted October 09, 2007 - 11:33 AM
If you didn't reseted the computer after attaching the sensor, then here's the problem.
  • trippinwilly
Posted October 09, 2007 - 02:40 PM
I was riding out toward Tecate 3 weeks ago and did a nice little flip over the bars, smashing my speedomter, headlight, and tail light. I have wanted to get the Trailtech for sometime, but did not want to spend the money because there was nothing wrong with mine. Looks like I will be ordering one soon, I like the way it looks, I would like more info on how accurate the engine temp is. Does anyone have the XR's only dipstick and the Trailtech sensor? How does it compare? Any input is appreciated!
James
