Touble getting XR650R to idle
10 replies to this topic
  • NMike
Posted February 24, 2007 - 04:06 PM
the bike had been sitting for a few years. and yes i foregot to remove the old gas.:applause:
so i took off the carb. cleaned it out as best as i could. blew air through all the holes, installed 175 and #68 jets. needle is on the fourth from top groove.
i can start it but the idle has to be very high. i can turn it down. after a few seconds it'll just stall out.starts right away, then stalls when the idle is not on high speed.
did i do the floats right?
as a side note. where do i route this hose on the bike?
  • Big Red Paul
Posted February 24, 2007 - 04:29 PM
The fuel line or the fuel filter in the tank might be blocked, and the carb can't suck enough fuel through. The bike has been standing for a while, so this might be the problem.
  • NMike
Posted February 24, 2007 - 06:10 PM
well i replaced the fuel lines from the tank. it is a acerbis 6 gallon model.
has lots of power, runs good except for idling.
PS the bike is uncorked if that matters.
  • porterdog
Posted February 25, 2007 - 09:18 AM
Sounds like a sticky float to me, too.
On my carb the hose in question loops up and over at the front of the carb and then back down behind. The end doesn't seem to go anywhere critical, and it's just open.
  • Thumpage
Posted February 26, 2007 - 04:24 AM
You might have an air leak at the carb isolator boot between the carb and cylinder. Make sure the boot and clamp are in good shape and have good seal.
  • abby
Posted February 26, 2007 - 05:24 AM
That hose you have a pointer on goes straight up from the carb into that rubber thingie directly above the carb on the frame and the hole faces backwards (towards the rider).
  • NMike
Posted February 27, 2007 - 11:01 PM
thanks, i'll get a new float and needle. see if that helps.
  • Kawabuggy
Posted February 28, 2007 - 07:48 AM
I agree with the vacuum leak scenario. An engine that will only run at a high idle is most likely suffering from an engine air/vacuum leak. As mentioned above, check for air leaks!
  • HawkGT
Posted February 28, 2007 - 08:27 AM
Where's your fuel screw set (how many turns out)? Around 2 turns out would be "normal".
  • roadrunner81
Posted February 28, 2007 - 08:46 AM
pilot jet is plugged
  • NMike
Posted February 28, 2007 - 09:15 PM
pilot jet is new and i blew through the passage.
