THROTTLE STOP MOD???????????
3 replies to this topic
  • DANSOCAL
Posted January 18, 2002 - 06:11 PM
HOW DO I PULL OF THE THROTTLE STOP MOD.(IN DEPTH INSTRUCTIONS)???? HOW MUCH TO GRIND??? WHAT ELSE SHOULD BE DONE TO A 02 WR426?????
  • Easyrider
Posted January 18, 2002 - 06:37 PM
Pull the screw on the Rt side, back of the carb that is colored a dark gray/black. When you pull it, it will have a long section that is not threaded. This is the stop. Cut the non-thread section off, or just take the screw and matchit up with a similar screw (same thread), and put the new shorter screw in there.
  • WRFUN
Posted January 19, 2002 - 03:49 AM
Dan,
Just go get the throttle stop for the YZ and be done with it. Then you will not have to worry about cutting off to much.
Pete
  • wayneoXCF
Posted January 19, 2002 - 05:33 AM
The screw should be 23mm long, total.
