Zip Ty problem
4 replies to this topic
  • John221ex
Posted February 22, 2007 - 06:37 AM
In trying to install the the mixture screw, I was unable to remove the stock screw. The float bowl had to be removed to get it out. Then, the new Zip Ty would not go in with the bowl on. Apparently there is some misalignment which prevents the threads from making contact with the seat.
Am I missing something obvious, or is it not meant to work the 400 carb?
John
  • clark4131
Posted February 22, 2007 - 06:47 AM
There are two types of Zip-Ty screws for the Yamaha based on the year. This is the one you need according to the website. Did you get the right one?...SC
  • SXP
Posted February 22, 2007 - 06:54 AM
John
There's no problem, this is normal. The screw will not come out with the float bowl in place. What you have to do is, remove the float bowl and use a drill (can't remember what size - use the next size up from the bit that easily slides in and out of the fuel screw hole in the float bowl) and ream out the hole in the float bowl - it doesn't take much. You can then completely remove and install the fuel screw with the bowl in place. I've had to do this on the three WR's I own.
  • John221ex
Posted February 22, 2007 - 07:41 AM
I did try reaming it somewhat, but I still can't get even the stocker to go in that way.
No, I didn't know about the earlier version of the Zip-Ty. That's why I'm here! Thanks!
John
  • SXP
Posted February 22, 2007 - 07:51 AM
John
You might try keeping the float bowl bolts a little loose while working the fuel screw in so there's some slop, and once in, tighten the bolts up.
