2003 yzf 450 hot start??????
14 replies to this topic
  • weston24s
Posted February 19, 2007 - 01:54 PM
just bought a 03 yzf 450 this weekend and the guy i got it off had taken the hot start off cause it messed up and it was nounted under the tank i think and then got stuck in the carb.........my question is what all do i need to get to put it on the handlebars?????what cable??????? please help
  • Jaycycle
Posted February 19, 2007 - 01:59 PM
Its hard to understand what you need but here is the cable. #11
http://oem.thumperta...witchlever.aspx
  • weston24s
Posted February 19, 2007 - 05:11 PM
i have nothing on the bike im wanting to know what is needed to put the lever on the bars?i have no lever or nothing????????
how does it attach to the carb????
cause its all missing??????????
  • Jaycycle
Posted February 19, 2007 - 05:37 PM
So there is nothing on the carb for the hot start??? The plunger or something should be in there, or to much air would be getting in. Everything you would need is in the link I posted. Get everything except the clutch assembly.
  • motokid338
Posted February 19, 2007 - 05:42 PM
Are you asking how to istall it...or do you have something already on your bike...I dont understand what your asking..I have the same bike with a Dr.D hotstart.
  • Ga450owner
Posted February 20, 2007 - 05:59 AM
You will need these: for adding a Hotstart lever on your handlebars with all the other parts if you have no hotstart -
A DRD HotStart lever or just buy the Hotstart Kit complete - it has everything assembled and ready to install.
http://www.dubachrac...bachRacing.html
OR
The individual OEM parts:
a Hot start cable assembly - see part number from above
parts 36-41 from Here:
http://www.yamaha-mo...parts/home.aspx
36 5TA-14371-00-00 .PLUNGER, STARTER 1
37 5TA-14335-00-00 .SPRING, PLUNGER 1
38 5TA-14991-00-00 .SCREW 1
39 5TA-14374-00-00 .CAP, PLUNGER 1
40 5TA-14155-00-00 .GUIDE, CABLE 1
41 5TA-14997-00-00 .SEAL 1
I suggest you buy a ZipTy Racing Hotstart Screw instead of #38 as it is metal and will keep all moisture out forever vs plastic oem cheap
http://www.ziptyracing.com
  • weston24s
Posted February 20, 2007 - 07:12 AM
ok thanks all i needed is parts list
Posted February 20, 2007 - 10:16 AM
Also, on the list of OEM parts, you would need:
1) 5TA-26334-00-00 cable
1) 5XD-82946-00-00 HOLDER, STARTER LEVER
1) 5TA-83941-00-00 LEVER, STARTER
1) 95607-05100-00 .NUT
1) 90149-05162-00 SCREW
1) 5TA-26339-00-00 BOOT
(Lever assembly and cable.)
You can use after market levers, such as the Dr.D, or use a clutch perch like the ASV or Works Connection with a hot start lever built in, but you'd need the cable anyway, unless you bought a complete after market kit. I'm not certain that such kits exist for the 450's, which came with a handlebarf mounted hot start from the factory.
The plunger will almost certainly be in your carb, along with the return spring, and at least part of the cap. Otherwise, there would be a full time air leak in the cicuit.
  • Ga450owner
Posted February 20, 2007 - 11:09 AM
GreyRacer is right - you need to see what is in the carb plunger hole
To be safe just get the DRD HotStart Kit - it has everything you need
Posted February 20, 2007 - 11:43 AM
Hey, Dave,
I just had a though about this that sent a shiver down my spine. Can you think of a reason why the lever and cable might be removed? I can. :applause:
  • Ga450owner
Posted February 20, 2007 - 01:12 PM
Hey, Dave,
ebay or pieced together....?
Posted February 20, 2007 - 01:17 PM
No, I was thinking, "stuck in carb for the last 6 months" :applause:
  • 2wheels-drz
Posted February 20, 2007 - 01:53 PM
so was the bike running when you bough it??
  • Ga450owner
Posted February 20, 2007 - 04:15 PM
if so that will be a SOB to get out:cry:
  • weston24s
Posted February 24, 2007 - 07:59 AM
runs fine without but id rather have it and yeah it was stuck had to drill it out tap it put a bolt in it heat it up and pull it out
  • Hot  30 replies
  • Hot  28 replies
  • Hot  47 replies
  • 0 replies
  • Hot  50 replies
