XR650l -will start -only idle with choke-backfiring
6 replies to this topic
  • TahomaTom
Posted February 19, 2007 - 12:30 PM
Ok first the L would not start so I went and got some gas. :applause:
I filled her up and it started right away :lol: but wont idle with the choke off.
I can ride it :cry: but need to keep the choke open 1/4 to 1/2 of the way when I come to a stop sign.:
I can turn the choke off when riding and it pulls ok but it back fires a little bit.
I checked the plug and air filter and it looks good. I got a new CDI about 500 miles ago.:applause:
The only thing i can think of is that my clutch cable is starting to fray but it has been like that for 5-6 rides before I parked it and has never been a problem. Is it hard to replace
Oh yeah one more thing the idle did cyle a bit at the last stop light. Went up than down and the choke was on.
Any suggestions?
the bike a 94 650l 14K, is jetted, exhaust, smog off, clarke tank etc.
Thanks for the advice in advance-
  • JackAttack
Posted February 19, 2007 - 12:36 PM
Pull the bottom off the carb and clean the main and pilot jet. You should be able to see through both.
  • creeky
Posted February 19, 2007 - 01:31 PM
Carb need cleaning.
  • Motosprtman
Posted February 19, 2007 - 01:43 PM
or a loose jet... had one fall into my float bowl once made for all kinds of fits.
  • motomonte
Posted February 19, 2007 - 06:50 PM
Make sure it's not leaking air...check the boot between the carb and the head.try spraying some wd40 in that area,if it's sucking air the roughness should go.
  • XR650L_Dave
Posted February 20, 2007 - 08:52 AM
A few thoughts:
- could be water in the gas
- if it has had the pilot jet replaced, and they used a long pilot jet, the slosh baffl could be blocking the jet
- fuel screw got bumped?
- latest batch of gas was gasohol (makes the jetting 14% lean for a 10% ethanol mix)
Dave
  • xrltim
Posted February 21, 2007 - 08:20 PM
That will be the pilot jet being partially or fully clogged. It is the smallest orifice in the engine and sitting for a lengh of time or dirty gas can easily plug it up. Especially a problem in small engines. A buddy of mine has gotten many a good deal on little bikes for his kids because they wouldn't idle without the choke. Easy fix.
