Exhaust problem.Is this bad???Photo
9 replies to this topic
  • christoswr
Posted February 19, 2007 - 07:26 AM
I just installed a new slip on and i saw that it comes in contact with the rear shock absorber!
Is this bad or not?
Check out the photo!
http://i135.photobuc...ia/DSC02648.jpg
  • Jaycycle
Posted February 19, 2007 - 07:29 AM
Oww yeah, I don't think you want to be heating that up! I could be wrong, but I would bend the pipe in a little bit in, just so it isn't touching.
Lets see what others say.
  • Gerry B
Posted February 19, 2007 - 07:38 AM
Yasou Christos!
Nice to see a fellow Greek.
What kind of pipe is it?
  • christoswr
Posted February 19, 2007 - 08:01 AM
Yasou Christos!
:applause: :applause: Yasou kai sena!!
Its a White brothers E-Series.
  • christoswr
Posted February 19, 2007 - 09:08 AM
Anyone else?:applause:
  • tammie
Posted February 19, 2007 - 09:10 AM
can you wrap some heat shield around the pipe?
  • christoswr
Posted February 19, 2007 - 10:36 AM
I think i wont be able to do that since there is no space between them!!
  • yzfireguy
Posted February 19, 2007 - 10:54 AM
I would call WB and tell them what your dealing with. Your shock makes enough heat in itself and I wouldn't think adding the added heat of the exhaust (which is quite a bit) would be a good think. IMO
  • MikeDD
Posted February 19, 2007 - 10:58 AM
The shock reservoir is going to get very hot when riding reguardless of the exhaust location and this is totally normal. With heat though, comes a change in performance characteristics as the oil and nitrogen are heated. I would do your best to minimize the heat exchange to the shock from the exhaust. If the pipe is in direct contact (hard to tell from the pic) with the reservoir I would see what you can do correct that. You don't want those two components sitting on each other. If there is a small gap you should be fine. Start by calling the company and see what they say, I'm sure they have been asked this question before.
  • christoswr
Posted February 19, 2007 - 11:24 AM
There is a tiny gap between them!!
  • 0 replies
  • Hot  36 replies
  • On January 15, 2017
