motor oil ok?
16 replies to this topic
  • dirtrider95018
Posted 18 February 2007 - 01:16 PM
is it ok to use syntec castrol oil 10w-40 in my 02 wr250
thanks
  • 250Thumpher
Posted 18 February 2007 - 02:04 PM
Castrol isn't a very good oil. It doesn't hold its wieght well at all.
Use Shell Rotella T or T synthetic. Get it at Walmart
  • intensem1rider
Posted 18 February 2007 - 03:32 PM
Nope, can't use the castrol. It's has certain friction modifiers that will cause your clutch to slip. You need a synthetic oil that is designed to be run where the oil lubes the clutch and motor. I run Amsoil synthestic motorcycle oil.
Look for an oil that is JASO MA rated, and is NOT labeled API ECII, or "Energy Conserving".
  • 250Thumpher
Posted 18 February 2007 - 03:51 PM
Castrol GTX worked fine, but I wanted better protection....
You need to look at the genetic makeup of the oil, to see if it contains any moly. Look on bobistheoilguy.com for oil analysis...
  • yamaha586
Posted 18 February 2007 - 04:58 PM
what kind of oil should i use in my bike (05 yz250f) automotive oil? or dirt bike oil from the shop? and when should it be changed? and do i have to clean or replace the iol filter? how do i clean it?
  • Honda_250f_rider
Posted 18 February 2007 - 05:23 PM
I would use a motorcycle specific oil to be safe
I use Pennzoil's outdoor motorcycle 10w40 in my bike, zero problems
The trick is to use a motorcycle specific oil and change the oil frequently, like 3-4 hours, I think that is more important than buying the more expensive full synthetic oils and leaving them in for 8 hours.
  • yamaha586
Posted 18 February 2007 - 05:26 PM
doesnt it matter wat temp you ride in? in the summer here in nj its around 75-100 degrees but spring like 60-75 should i always run the same weight oil? or get thicker or thinner?
  • Honda_250f_rider
Posted 18 February 2007 - 05:30 PM
In the summer time I run 20w50 and when its a little cooler out I use the 10w40
Edit: For the oil filter, I would replace it every 15 hours or sooner.
  • yamaha586
Posted 18 February 2007 - 05:34 PM
ok thanks alot 250f rider
  • intensem1rider
Posted 18 February 2007 - 06:09 PM
I always run 20w50 amsoil synthetic motorcycle oil, cold or warm weather. The only time I see an effect of the thicker oil is when im trying to start my bike when theres snow on the ground, the bike chugs a little, but once the engine warms up, so does the oil.
  • George_Felix
Posted 19 February 2007 - 05:32 AM
Amsoil synthtic is $32 a gallon. A good non synthetic is around $16 a gallon. Rotella is available at Walmart probably cheaper yet.
  • 250Thumpher
Posted 19 February 2007 - 07:08 AM
The Rotella T synthetic is available for about 16 bucks for a gallon. Works great, doesn't interfere the clutch, and from the looks of my old bike, it lubricates really well. If you also look at oil analysys new, it's up there with a lot of motorcycle specific oils, some of them are worse!
Looking at the difference between its new and old oil analysis, it stays within it's wieght rating really good.
I even left my bike off for 3 days and checked the valves. There was still a boatload of oil up there.
Shell even states that Rotella is really good for motorbikes.
It doesn't need to say Motorcycle on it to be good, you need to look at the genetic makeup, not the name...
  • Rootuser
Posted 20 February 2007 - 01:58 PM
Question here, and I am not asking for a religious answer, just some fact if anyone has real world performance data:
I have been looking in to oil a lot lately thinking my use of Motul 300V might not be a good idea due to it's 92PPM of Moly. Almost every oil contains some moly, but most of the "non-moly" oils contain less than 5PPM (almost none essentially).
Yamaha (and other too) state the use of JASO approved oil is a requirement. most of the Shell Rotella oils I found at Walmart do not meet this standard. It has something to do with Ash content etc. Since so many people are the "Follow the manual" types, and I am personally not, I want to know this:
Do you have find any dark areas past the rings when using Shell Rotella??? Just darkness, not actual build up. I find none when using Motul, and the 300V is JASO certified meaning it does not contain X amount of Ash and it will not cause clutch slippage, but maybe Shell Rotella is just as good and the whole ash thing is a myth?
Just curious if anyone can help.
Thanks!
  • 250Thumpher
Posted 20 February 2007 - 02:33 PM
I think the ask in the oil is to controll the soot produced by the Diesel motors, and does not apply to gaoline motors.
Correct me if wrong...
  • SUnruh
Posted 20 February 2007 - 02:41 PM
rootuser,
don't worry about ash.
what you should worry about is keeping an oil in your motor way past its change time due to the price you paid for it.
this motor will run just fine on (let's do some quick math -> 0.79 x 4 = $3.16 per GALLON) oil.
and once again (# 6.022x10^23), no more really needs to be said about oil.
  • Rootuser
No, this is actually about the ash content in the oil itself. It cannot have more than 1.2% Ash content to be consider JASO certified. Shell Rotella Synthetic does not meet this standard, it has 1.47% Ash content.
My question is, if i were to "Follow the manual" I couldn't use Shell Rotella oil, but really, does it actually make a real world difference?
What about those dark spots past the rings? Ever seen em? It would look like wear, it would just be darker than the ring was when new from what I understand. I have never seen it personally.
  • Rootuser
Posted 20 February 2007 - 02:46 PM
Thanks SUnruh good point. I figure I change the oil so often it doesn't matter. I use Motul 300V currently and I change the oil every ride and throw the air filter out every other ride hehe. Totally overkill I know, but that's just me. I can also eat off the head it so clean, even after hours and hours and hours :D
I might make the switch to the Shell product as it is just so much cheaper, but I had partial sponorship from Motul back in the day its just hard to step away from a group that treated you well.
