Quite a bit of oil out of the breather
6 replies to this topic
  • Drav
Posted February 18, 2007 - 10:39 AM
It's a 02 YZ426F, I know that it drools when ran hard, but this seems to be quite a bit of oil, a couple hours of riding and the left side of the bottom frame by the hose is covered, as is my boot...is THAT much oil normal? It's not overfilled either.
  • Slinkyman16
Posted February 18, 2007 - 03:05 PM
i have the same bike.. and its been happinging since day 1.
  • Edge316
Posted February 18, 2007 - 04:13 PM
my 07 yz450 has also done the same thing since day one.my local shop says it is normal for the yz450.
  • never59
Posted February 19, 2007 - 07:17 AM
How much oil do you put in after a oil change? Most importantly when you take out the oil filter? If excess oil is coming out that usually means you put too much oil in but sounds like you already know that. If the oil level is still in good shape after the breather dumping oil then you are fine but that would indicate you had to much oil in it
  • Dolce_Grappa
Posted February 19, 2007 - 08:17 AM
From previous discussions, it was pointed out to from be running high-rpm's. My question is, if you all notice the oil getting out, what are you using to keep dirt from getting in to the cylinder head?
  • tom nolan
Posted February 19, 2007 - 09:40 AM
Same thing with my 400. I started using Rotella 10/40 and it seemed to cut the juicey breather problem in half.
  • Drav
Posted February 19, 2007 - 05:34 PM
The breather is at the top of the valve cover and is about 20 inches long, would have to put the bike completely upside down and poor dirt into the tube to get even near the cover.
I use 1.5L on an oil change, and my oil levels dont really drop after rides, so Ive evaluated that it's just the normal drooling that the bike will do when ran hard.
Thanks guys.
