Hot cams install / assembly lube?
16 replies to this topic
  • STRAIGHT EDGE
Posted 18 February 2007 - 12:56 AM
I'm installing a set of hot cams (new), do I have to use assembly lube, or will a sufficient amount of oil work? Thanks
  • intensem1rider
Posted 18 February 2007 - 03:30 AM
Engine assembly lube is reccomended however not needed if you can't spare the $5. just be sure to dump oil in the cam area before you put the valve cover on.
  • weedhopper
Posted 18 February 2007 - 08:27 AM
I just use liberal amounts of oil when I put my cams in.
  • 250Thumpher
Posted 18 February 2007 - 11:59 AM
It's cheap, just get it. Any auto parts store carries it.
Oil isn't sufficent enough. You need a really thick oil. This is where assembly lube comes in. It's like grease almost.
  • STRAIGHT EDGE
Posted 18 February 2007 - 12:10 PM
Thanks for the info. I had read on the thumperfaq.com that some assembly lubes may effect the clutch. Anyone had any problems with this? Thanks
  • 250Thumpher
Posted 18 February 2007 - 12:13 PM
When I did my motor I have not. Change the oil shortly after.
  • Birdy426
Posted 18 February 2007 - 11:13 PM
Just make sure the assembly lube doesn't have moly or graphite in it...either will cause clutch slippage. AutoZone sells some moly/graphite free assembly lube. STP works good, too.
  • mn519
Posted 19 February 2007 - 10:09 AM
oil will work fine if you gonna be starting it shortly after assembly. The reason for assembly lube is for engines that are assembled and not started or oil-primed for some time after assembly.
  • ONLY4STROKES
Posted 19 February 2007 - 11:02 AM
Assembly lube is dirt cheap, and reccomended. Why risk it? Oil isn't really sufficient enough for a job like this.
http://www.hotcamsin...Video&videoid=3
  • Rootuser
Posted 19 February 2007 - 01:32 PM
The assembly lube is to protect everything during a dry start-up. It's probably worth using it.
  • mn519
Posted 19 February 2007 - 02:18 PM
Its not dry if the oil was just put there. Thats how i was taught to do it by someone that was a nascar engine builder and is still a certified nascar race tech. He said the assembly lube stays there and is good if your assembling a motor and not starting it right away, but that if your starting it right away its no different to use straight oil.
  • STRAIGHT EDGE
Posted 19 February 2007 - 08:01 PM
I bought an assembly lube with moly-graphite in it, installed cams already. I havent started the bike yet, but will the moly-graphite affect the clutch if I just ride the bike for about 30 mins to break it in and then change the oil? I read the responses to my post after install. Thanks
  • Birdy426
Posted 19 February 2007 - 09:56 PM
From everything I've read, YES. Both hot cams and Yamaha recommend against using assembly lube with moly or graphite in 'em, as does Eric Gorr and every article I've ever read in Dirt Bike, Dirt Rider, Racer X, etc. The non-moly/graphite lube is only about 4 bucks a tube. A heck of a lot cheaper than a new set of clutch plates!
  • STRAIGHT EDGE
Posted 21 February 2007 - 02:09 AM
Should I pull the cams back out, clean and re-install with non- graphite assembly lube? Thanks
  • 250Thumpher
Posted 21 February 2007 - 07:43 AM
Your motor, but I would.
What's cheaper, assembly lube or the risk of a new motor?
  • STRAIGHT EDGE
Posted 26 February 2007 - 12:29 PM
I finally found a moly and graphite free assembly lube. I pulled the cams, and lifter buckets out fully cleaned and re-assembled. Worked perfect. No clutch slippage.
  • Dano426
Posted 08 March 2007 - 06:59 AM
I am having a hard time finding an assembly lube that says it does not have moly or graphite. Clevite Engine Parts - Cam Guard is the only one I can find that does not have graphite listed. Anyone have a brand that hey are using
Thanks
Dan
