Riding today and noticed then engine had a slight but fast tick to it, what would be the cause of this, is this bad, and how can you fix this?
yz250f engine ticking..
Started by aussie_yz250f, Feb 17 2007 10:29 PM
8 replies to this topic
Posted 17 February 2007 - 10:29 PM
Posted 18 February 2007 - 01:37 AM
Hi.
When was the last time that you have checked the valves?
There could be many reasons for the ticking.
Try to use a freind (to double check) and find out from where it is ticking.
Is it from the clutch side?
Magneto Side?
Engine ,top end?
Lower engine? (mybe berings)?
Again' my guess will be from the valves.
Good luck.
Magneto Side?
Engine ,top end?
Good luck.
Posted 18 February 2007 - 12:10 PM
Hold a pipe up to the motor and use it as a stethescope and get back to us when you pinpoint the cause.
A gargen hose works great, copper pipe about 1/2" to 3/4" diamater works great too, as does Conduit. Just hold one end on the surface of the motor, the other end goes to your ear...
Be sure to not let the motor get too hot by directing fans towards your radiators and header.
Posted 18 February 2007 - 12:25 PM
Seriously? :lol:
Posted 18 February 2007 - 12:26 PM
Jaycycle said:
Seriously? :lol:
Don't believe it works? Go try it right now, it's a old but cheap trick.
Posted 18 February 2007 - 12:30 PM
No, I believe you alright. I was just wondering if people actually do that (and works), it so funny. :applause: No doubt in my mind...
Posted 19 February 2007 - 04:40 PM
its the edition that had the 3 intake valve recall, the bikes 5 months old shouldnt have issues with valves..
Posted 20 February 2007 - 01:46 PM
Was the recall done?
Again, take a pipe to the motor and let us know where the noise is comming from. You cannot diagnose this problem without knowing exactly where the sound is comming from...
