Advice on a used XR600
7 replies to this topic
  • Atrovent
Posted February 17, 2007 - 09:53 PM
I'm looking at a '95 XR600 for cheap (less then a grand). The catch is that it's using a small amount of oil, and in 4th gear the bike grinds and jerks. All the other gears are smooth. Otherwise in good shape. Thoughts on what could be wrong and how much it might cost? Thanks for you help. :censored:
  • Nummie
Posted February 17, 2007 - 10:17 PM
You're looking ar another 4 or 5 hundred for an ebay transmission, a weisco piston & rings, and a gasket kit. More if any bearings, cam chain tensioner, ect....
  • creeky
Posted February 18, 2007 - 06:01 AM
If the tranny is damaged, the broken pieces have done other hidden damage, beware.
  • cleonard
Posted February 18, 2007 - 09:38 AM
As Creeky says there could be other collateral damage. The main factor is -- are you willing to do the work yourself, or would you be having a mechanic doing the work. If it's a mechanic I'd guess that you are looking at at least $1000 if not $1500 or more to fix the engine. It would be a lot less if you can do the work.
Just guessing it sounds like it needs 4th gear. There are likely other transmission issues like 3rd gear and possibly a shift fork or two. If it's using oil it may need rings. It may need a new piston and bore. It would be good to have the head looked at and a valve job done if needed. It could also use a new cam chain and tensioner.
The parts have value. If you get the bike and it needs too many things fixed, just strip it and sell the parts on ebay. I bet that the pieces will get more than $1000 on ebay.
  • focallength
Posted February 18, 2007 - 02:43 PM
I know a guy in so.Cal who is very reasonable and has tons of experience with XR's. To install rings, gaskets and mill the head (if it needed it) was about 200 bucks.
For a complete engine rebuild (labor, machine work and parts) your looking at about 800-1200 depending on how many new parts are needed
give him a call he really knows his stuff
909-825-7064
canyon racers
www.canyonracers.com
  • Atrovent
Posted February 20, 2007 - 08:32 PM
Thanks for the heads up about that shop. I had thought about using Norm's Cycles in San Bernardino. They did some work on my street bikes. Anyone have luck with them?
  • asf
Posted February 20, 2007 - 09:28 PM
909-825-7064
canyon racers
FOr a complete rebuild that sounds really cheap, parts alone would be that if you need cam, chain, valves, springs, conrod, bearings, tranny, clutch, puiston, gaskets, oil pump, etc.
  • Watsabi
Posted February 23, 2007 - 05:51 PM
Personally I got a 97 xr600 because I wanted to learn to wrench myself. seamed easier that my 78 yamaha twin. I'm looking at doing a ring/valve job comming up here this spring
  • Hot  35 replies
  • Hot  28 replies
  • 2 replies
Honda XR650L 2016
  • 0 reviews
Washington
  • Hot  32 replies
