Recently the rear brake line got burned and leaked from the exhaust on my 250F. Well I have now put on the new brake line, added fluid and the thing still spins freely when I push down the lever (which has no feeling to it anyways).
Also, on my front end. I carelessly bled the brakes completely wrong, I opened up the 8mm nut by the disk, then squeezed the lever and let it free, then tightened it back up. As of now, the front tire is always breaking, it is very hard to push (the brakes are engaging) and the lever has only a small amount of space to break because it is so loose.
Yes both brakes arent working, but dont worry it's winter in Canada and Im not riding right now.
Thanks alot in advance, I know someone will know what to do.
