Bar risers
4 replies to this topic
  • iestrada
Posted February 17, 2007 - 01:43 PM
I've already did a serach for this subject, and i like som emor info.
My current set up is protapers, soctts tripple clamp, scotts damper. I want my bars a little higher and a little forward (1.5" will do both directions) do you guys have any suggestions?
Do i need to get the scotts SUB?
Thanks
  • Moredesert
Posted February 18, 2007 - 10:26 AM
If you have a Scotts tripple clamp you can turn the bar clamp base to change the position. The mounting hole is offset. You will need to change the damper mount as well because the pivet point will be different. I added 20mm bar risers to one of my outer bikes. It just fits under the bar clamp with longer bolts
  • iestrada
Posted February 19, 2007 - 12:16 PM
do youhave a pic of yur setup?
  • drop
Posted February 19, 2007 - 12:21 PM
What bend protapers are you running?
  • kex
Posted February 19, 2007 - 05:28 PM
I purchased risers from dirtbikepro.com mine are 1.4'' high and 7/8 forward ,big diffrence for the standig position
