DOT vs not DOT
7 replies to this topic
  • eissinger4
Posted February 13, 2007 - 12:46 PM
What's the difference between a DOT approved turn signal, and one that isn't?
  • CSS9961
Posted February 13, 2007 - 01:15 PM
Don't know for sure, but I assume the light has to be a certain brightness, and be able to be seen from a certain distance, and also be a certain height off the ground. For example, an aftermarket turn signal lamp that has a smoke tint would probably not be DOT approved, as it could not be seen as clearly as a clear lens.
Some states are more picky than others in what they will let you get away with.
  • MSHAM
Posted February 13, 2007 - 01:18 PM
There may be an issue with the total area of the lens.
  • Rich_in_Orlando
Posted February 13, 2007 - 01:29 PM
For real interesting reading, go here:
http://frwebgate.acc...=1999&TYPE=TEXT
  • CSS9961
Posted February 13, 2007 - 02:05 PM
I'm waiting for the movie, thanks....:censored:
  • byggd
Posted February 13, 2007 - 02:11 PM
The LED are the brightest ones on the market and most are not DOT approved.....just doesn't seem right.
  • CSS9961
Posted February 13, 2007 - 07:54 PM
Could be too bright. There are automotive light bulbs that are brighter than stock, and labled for closed course use only.
  • eissinger4
Posted February 19, 2007 - 05:41 PM
Thanks for the responses!:applause:
