Considering a rebuild-TI or SS valves?
11 replies to this topic
  • ckulzer
Posted February 13, 2007 - 05:43 AM
Good day,
I have 132 hours on my '03 450. I am considering a rebuild before I start the enduro season.
Any comments on Yamaha versus Aftermarket (it's the fight of the year) as I ready my wallet?
Thanks
Chad
'03 WR450
'01 TTR-L
Tons of junk that could be made into another couple of bikes - perhaps the new Honkawzukaha should start development.
  • jams229
Posted February 13, 2007 - 05:57 AM
Kibblewhite stainless would be my recommendation.
Quality product; long-lasting valves.
  • ckulzer
Posted February 13, 2007 - 07:15 AM
Jams229,
Do you have any first hand experience with the Kibblewhite products? If so, please share with the group. What benefits has the product brought to you? I am thinking that I would buy new Yamaha valves - only because I know they have worked good so far.
I am considering the rebuild as a preventative measure. I have owned the bike since new and it has never given me a problem. Just like replacing the radiator hoses and brake fluid, I am thinking that the internal bits are getting tired too.
Chad
'03 WR450
'01 TTR-L
  • fershy
Posted February 13, 2007 - 09:00 AM
Just a quick piece of succinct advise before you unload your cash.
"If it aint broke don't fix it."
fershy
  • jams229
Posted February 13, 2007 - 12:16 PM
Jams229,
Chad
'03 WR450
'01 TTR-L
My experience is with a set of their ss valves for my CRF450X.
I replaced the two exhaust valves. Noticed no decrease in power at all,
and expect them to last a good deal longer than the titanium ones.
I don't understand the use of titanium by the way.
Hope that helps a little!
  • 642MX
Posted February 13, 2007 - 12:27 PM
You shouldn't need valves at 130 hours. Properly cared for Ti valves should last 400-500 hours. I would go ahead and replace the valve springs, cam chain and rings.
  • Birdy426
Posted February 13, 2007 - 12:34 PM
From a wallet perspective, by the time you buy the KW springs, retainers, etc, it's about a push with replacing with all stock (from the TT store). At least that's the way it worked when I priced them for rebuilding my 426...(I went with stock Ti for a variety of reasons, not the least of which is the stockers performed flawlessly for more than 7000 miles.
  • kyle797
Posted February 22, 2007 - 07:27 PM
KIbblewhite makes great products we use their products in our Ducati race and street heads they are very durable.However the ducati Desmodronic valve system design uses no valve springs to close the valves so valve weight is not much of a factor. One thing to keep in mind is that the valve spring pressure keeps the valve in time with the cam if it does not keep it in time then valve float can occur and the piston can hit the valve and bend it. Titanium is used because it is 50 percent lighter than steel and lighter springs can be used to keep the valve in sequence( this is why racing cams sometimes come with new stiffer springs).So in theory a heaver stainless valve should need and come with stiffer springs. The problem with stiffer springs is that more load is applied to the cam lobes and the springs can pound the valve seats into the aluminum head and cause seat migration which is seen when valve clearances tighten up. I would inspect the stock valves for pitting on the 45 degree valve face measure the valve steam diameter and the valve length all the valve dimensions are in the service manual also measure the valve spring lengths,If the tolerances are exceeded then replace the worn parts.
  • crooks420
Posted February 22, 2007 - 07:43 PM
Some good tech info there...... Nice job.
Jesse
  • Fullbore4
Posted February 22, 2007 - 08:32 PM
Yah thanks Kyle.........good info to know.
  • CRF45OX
Posted February 23, 2007 - 05:46 AM
i asked a fabricator at work and he says that titanium IS stronger than stainless steel and it is lighter.
stainless is steel with added metals that make it stronger and has non rusting properties, but titanium is a whole new element that is stronger - although i havent drilled into titanium before so i cant talk from personal experience.
Although i also know that with worked engines in cars - you can get stainless valves but all the top end race cars use titanium.
Didnt crf's used to use stainless valves? and maybe they still do? that would probably explain their dreaded valve issues.
  • CRF45OX
Posted February 23, 2007 - 05:55 AM
AHHH HANG ON, I FOUND PROOF....
Titanium
Titanium instruments offer distinct advantages for delicate and micro surgical instruments. This space-age alloy is considerably stronger than stainless steel, yet it is lighter (43%). Because of its light weight, titanium provides enhanced sensitivity when interacting with tissue and suture.
Titanium is also highly corrosion resistant, eliminating worries about rusting and pitting. Its anti-magnetic property provides superior needle handling ability by eliminating bothersome magnetization problems.
Snowden Pencer titanium instruments are long-lasting and durable, and can withstand all types of sterilization. For reduced glare and ease of identification, titanium instruments are anodized blue.
