gearing a 650r
3 replies to this topic
  • 650r
Posted February 12, 2007 - 09:20 PM
what are you guys running for gearing and why? is there a better set up then stock? i ride alot of open desert and glamis alot, if that helps. thanks
  • XR4DEZ
Posted February 12, 2007 - 09:27 PM
I use the stock gearing even though I'm looking for 6th gear in the washes.It's good in the rox and tight stuff and those endless whoop section around the Sups and Plaster City.Most of the fast guys use 15/48.
  • Potts228
Posted February 12, 2007 - 09:34 PM
For open desert it's a no brainer to go with 15 / 47. Even with the 15 / 47 you can do slow single track and then be able to open her up on the wide open trails / roads. If you spend more time on the slower trails then maybe the 15 / 48 or 15 / 49 would be a better choice. Not sure on Glamis.
  • Thumpage
Posted February 14, 2007 - 12:27 AM
If it is dune riding you are looking at, 14/46 is what you need to be running with a paddle tire and a stock length chain. This allows enough clearance of the paddles from the swingarm especially when going flat out at higher speeds. A 46 rear sprocket is the smallest that can be used as a 45 will leave the chain too loose and there will be no more adjustment at the axle. As it is, 14/46 is a great gear choice for the dunes. A ten paddle is what the XR650R wants and needs to be it's best in the dunes. The 10 paddles simply work better than an 8 paddle with the major torque the XR650R produces. The AMS Sandsnake 120/100 10 paddle is a great tire, :censored:.
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  35 replies
Washington
  • Hot  32 replies
Honda XR650L 2016
  • 0 reviews
