Uncorked XR650L, but still wanting more.
11 replies to this topic
  • Wuthrich10
Posted February 12, 2007 - 06:29 PM
My 2002 XR650L has been jetted with a white brothers E2, uni filter, snorkel removed. The front wheel is still very hesitant to come of the ground in 2nd, even with the clutch. Is there anything else I can do for some more power off the bottom. Oh, and I also have the stock 15/45 gearing. Thanks
  • bigredxr
Posted February 12, 2007 - 06:46 PM
Change out carb, also change frt sprocket to 14 tooth from a xr600r.:censored:
  • justicedone
Posted February 12, 2007 - 07:13 PM
14/48 gearing will give the bike much more pop...and close the hideous gap between 1-2 gears.
  • lrutt
Posted February 13, 2007 - 04:42 AM
+1 on the regear. 15/45 is just way to hi. I went 14/48 and can still go way faster than i should on such tires. It will cruise 70 with those gears and is way better at bringing the front up and trail riding.
  • Nummie
Posted February 13, 2007 - 11:53 AM
You still have the stock cam ?
  • rebelventurer
Posted February 13, 2007 - 12:25 PM
As others suggested regear, I am at 14/48 can ride wheelies through third gear. You can also put a quality header and an edelbrock or FCR carb on. And welcome to TT!
  • XR650L_Dave
Posted February 13, 2007 - 02:44 PM
have you drilled the slide and shimmed the needle?
  • xrltim
Posted February 13, 2007 - 03:03 PM
I've got a '94 with an XR's only silencer, stock header pipe. Re-jetted carb, and recently rebuilt top end with a 101mm piston. 10.25-1 compression ratio. But.....even before I did the piston the front end came up readily in 1st., and only a little clutch in 2nd. once up it easily rode the wheelie through 3rd. Now I've re-geared also to slow down 1st. gear at bit, 14/48 from 15/45. Like another poster said I can cruise the freeway at 65 or 70 without any problems. Top speed is down though from over 100 to around 90 or so. :ride: Plenty fast enough. Gets off the line real hard though. Way more rideable on the trails with the gearing this way.:censored:
  • cleonard
Posted February 13, 2007 - 04:44 PM
These changes will help the power some on quicker. The CV carbs have a built in delay due to the vacuum operated slide. Drilling it really helps it open quicker. Since you are in Texas, you are likely at low elevation. The shimming helps the mid range lean area.
  • Wuthrich10
Posted February 14, 2007 - 06:51 PM
Thanks guys, i do mostly street riding, probably about 75 on-road and 25 off road.Do you know what kind of mileage yall are getting with the 14/48 gearing?? Oh, and would adding a header pipe really make much of a difference?
  • Motosprtman
Posted February 15, 2007 - 11:59 AM
it does close the gap as mentioned - but I thought 14/48 was kinda buzzy on the highway. although I may still go back to 14/48 because of this post!
  • Wuthrich10
Posted February 15, 2007 - 02:25 PM
Sounds good, although I may get something in the middle like 15/48 because like I said i do ride mostly highway, 60-70mph about 15 miles one way.
FCR40 Tuning Woes- XR600R by aTuWitty
  • Hot  37 replies
What was your path to Beta? by officialhopsof
Dirt Bike   Make / Model Specific   Beta
  • Hot  79 replies
  • 3 replies
Can anyone identify this xr600 piston? by ms_mtn24
  • 4 replies
1993 XR600R rebuild by ove
  • Hot  41 replies
