front brake drags
9 replies to this topic
  • RJC
Posted February 10, 2007 - 07:23 PM
Front brake drags a bit spinning the wheel with bike on the stand. Should i be concerned and tear caliper/piston apart now? Rebuild?
  • needsprayer
Posted February 10, 2007 - 08:02 PM
Hold the front brake on to extend the pistons and spray the caliper with brake cleaner. Spin the wheel and apply brakes a couple of times. If the piston was a little sticky with grim it may clear up.
  • rebelventurer
Posted February 10, 2007 - 11:47 PM
First I would flush the brake fluid. Second I would disassemble and clean. Good luck with your stickiness.
  • bork
Posted February 11, 2007 - 05:52 AM
Start with a good flush. A slight rub is normal but does it slow down wheel fast? like a 1/2 a turn? Spin a coupls times first to get pads to spread a litle then see how fast it stops . Anyone else to compare it too? if I get mine up on stand I'll check for you, but presently my back is out & I lift my bike up on stand.
  • RJC
Posted February 11, 2007 - 08:20 PM
Thanks for the input, guys. Yeah, please let me know how yours compares, Bork. I'll pic up some brake cleaner tomorrow and try that first.
  • bork
Posted February 13, 2007 - 02:35 PM
OK, As fast as I can manually spin by hand.= 4-41/2 turns . I put a piece of masking tape band thru spokes around rim & tire, so I could plainly see number of revolutions. Hope this helps. I think this mine is normal?
  • RJC
Posted February 13, 2007 - 04:18 PM
Thanks Bork, mine makes about 2 turns. I think I'll just tear into it. Getting the manual out.............
  • HawkGT
Posted February 13, 2007 - 06:12 PM
Some drag is normal--the pads should be kissing the rotor. Some pads drag more than others when their just kissing (or full-on braking for that matter).
I'm getting about 3 1/2 turns out of my 02' XR650R with new wheel bearings and an EBC big rotor kit. EBC pads too, I think. You can certainly feel the friction but I don't think there's much to do about it. My 95' CR250R goes more like 7 or 8 turns [shrug].
Years ago I had a CBR900RR with dual 4 piston calipers. They had what I thought felt like excessive kissing friction. I rebuilt everything with little change. I eventually came to the conclusion that the EBC HH pads I was running was the cause. The pads performed well enough that I ignored the brake drag. I figure what feels like a lot to your arm is probably only eats a small fraction of 1 HP.
  • bork
Posted February 14, 2007 - 07:25 PM
hehehe , maybe I spin faster? BTW my rotor is slightly bent which may cause the puks to spread out alittle from the wobble action.
  • PeterGO
Posted February 26, 2009 - 06:55 PM
'98 XR650L
Anyone know exactly what I need to buy to refurbish my front brake caliper?
It sticks pretty badly. Is it necessary to replace it instead?
  • 22 replies
  • Hot  29 replies
  • 9 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
