seized swingarm bolt
7 replies to this topic
  • XR4DEZ
Posted February 10, 2007 - 01:37 PM
Nursing a broken wrist so i have a little time. I can't get the swingarm bolt out, the swingarm moves freely and there isn't any wobble or play in the bearings. What if I just forget about it for now and wait for the offseason? What could go wrong? thanx for your help.
  • Thumpmeister
Posted February 10, 2007 - 01:47 PM
If there is no play or wobble, why are you trying to take the bolt out?
  • XR4DEZ
Posted February 10, 2007 - 02:30 PM
I was going to grease the bolt and bearings, guess I was a little neglegent in my grease routine.
  • cleonard
Posted February 11, 2007 - 10:39 PM
First use some penetrating oil. Let it sit. Then if it still doesn't come out, beat it into submission. I use a 3/8 socket extension. It's just the right size to push the swingarm bolt through.
  • thouk
Posted February 12, 2007 - 10:08 AM
One thing that you might want to look out for with a stuck bolt is that if you beat on it too hard the bolt will mushroom. I know from experience. I had to cut the frame to get the engine out to switch it over to the other frame. Have fu, Tony
  • dburkett
Posted February 13, 2007 - 04:52 PM
Heat/brass punch.
  • thouk
Posted February 14, 2007 - 03:02 AM
I guess my BFH was not calibrated for the necessary torque that was needed. Mine would not budge. Tony
  • suharianu
Posted February 14, 2007 - 06:27 AM
you will have to drill it,head bolt was broken off,no matter how much pounding
it didnt want to move.it may bend with time, because its a hollow bolt if i remember correctly.
