Steering seems crooked?
11 replies to this topic
  • shoboat90
Posted February 05, 2007 - 09:34 AM
Wiped out last week on my 02 426 and now my steering seems crooked. When I'm riding, visually, everything doesn't seem to 'line up', i.e, handlebars, front wheel, etc. Where should I begin to look to diagnose the problem.
thanks
jim
Posted February 05, 2007 - 09:59 AM
Loosen the lower triple clamp pinch bolts. The forks are twisted in the clamps, causing the wheel to point off to one side. If they don't simply return to their proper alignment on their own, put the front wheel up against a pole or door jamb, etc., and turn the bars against it to push them back where they belong.
Be careful retightening the clamp; the correct torque is 14 ft/lb.
  • mkporn
Posted February 05, 2007 - 10:11 AM
What he said^^^^ common with YZ's when everything is torqued correctly. Its just like when you use to wipe out on your BMX bike, go smack the thing against a tree to bump it back in place.:ride:
  • shoboat90
Posted February 05, 2007 - 11:07 AM
Kind of what I thought....just wasn't sure of the procedure. You guys rock and thanks for the info.
Oh...still have gnarly scars on knees and elbows from those BMX days!!
  • Yamahafan
Posted February 05, 2007 - 11:37 AM
Gray,
I notice when torqueing the triple clamps if you torque the bottom bolt, you can go back and torque the top bolt again because by torqueing the bottom bolt you have removed some of the torque from the top bolt. I usually set my torque wrench to 13 ft/lb and iterate back and forth between the top and bottom bolt until they both cause the torque wrench to click. I also lube the threads with lithium grease, Bel-Ray waterproof grease, or assembly lube (but I don't like Bel-Ray assembly lube as much because it is charcoal grey and stains everthing in sight).
Am I overtightening with this method? :ride:
Posted February 05, 2007 - 12:08 PM
Yes, you are, because the torque spec is given for clean, dry threads unless otherwise specified. Adding lube to the threads, even in the form or Loc-Tite will increase the applied clamping tension on the bolt by as much as 20%, or more.
With any application in which a part is held by more than one bolt, torque must be applied evenly in successively larger steps up to the limit in order to assure that the torque on all fasteners is equal. This is particularly noticeable with clamping parts, like the triple clamps, axle lugs, etc.
  • skipperlantz
Posted February 05, 2007 - 06:26 PM
You probably twisted your forks. Loosen your clamps and make sure everything is straight. Also, if you have rubber bar mounts, they may have twisted. Loosen them at the bases and twist them back also, if that is the case.
B
  • Yamahafan
Posted February 06, 2007 - 12:47 PM
OK, so do not lube threads, but do iterate until all bolts are torqued the same. I think you mean successively SMALLER steps.
Thanks for the info.
Posted February 06, 2007 - 01:58 PM
Successively higher torque values, and yes, each higher step should be a smaller step up from the last, i.e., 5-9-12-14, or so.
  • CaseyWR450
Posted February 06, 2007 - 02:01 PM
thanks
jim
Same with my 01 yz250f
  • 00 Kracker 00
Posted August 17, 2007 - 07:36 PM
Good info, fixed my crooked wheel. THANKS !
  • jk9270
Posted January 29, 2008 - 02:02 PM
I have the same problem on my XR. Just a little crash caused it. Kind of embarrasing more than anything else.
Do I just loosen the lower clamps? I don't see how the bars/wheel can turn without moving everything.
  • 9 replies
Motocross
  • Hot  491 replies
  • Hot  36 replies
