XR600 Supermoto sprockets - where to buy from
4 replies to this topic
  • asf
Posted February 04, 2007 - 09:07 PM
I have a 40t aluminum from sprocketspecialists, but where can I find steel or "stealth' alum/steel sprockets in the smaller tooth range? I do lots of freeway so 14/40 is what I decided on based on the 4strokes.com gearing calculator.
  • cleonard
Posted February 04, 2007 - 10:19 PM
You can get a 40 steel from JT. I've not seen anything smaller. If you want to gear it out more, put a 15 on the front.
  • asf
Posted February 04, 2007 - 10:37 PM
40t is fine, 15t up front is too big because you cannot use a case saver which I like having "just in case."
JT doesnt seem to have a 40t on their website BTW:
http://www.jtsprocke...sel_uid=4182&p=
Honda XR600 R USA
1991 to 2000
Front Sprocket: JTF 1309.14
Rear Sprocket: JTR 301.48
Recommended Chain: : 520 / 110
Front sprocket available in: 13, 14, 15 teeth
Rear sprocket available in: 45, 48 teeth
Any recommendations on retailers to visit?
  • cleonard
Posted February 04, 2007 - 11:05 PM
I saw the 40 tooth listing at bikebandit.com. If JT says that they don't make it, then I'd believe them, not bikebandit.
I'm pretty sure that XR's only makes a case saver for a 15 tooth countershaft sprocket.
  • asf
Posted February 04, 2007 - 11:16 PM
Great, thanks for the link, they show all combos under the sun. I will try calling them. Im assuming this aluminum one I have right now will only last a few months. I dont feel like buying a new rear sprocket so frequently.
  • 9 replies
Honda XR650L 2016
  • 0 reviews
  • 3 replies
  • Hot  186 replies
  • Hot  35 replies
