Secrets To Pulling The Engine????
2 replies to this topic
  • stoneagegixer
Posted February 04, 2007 - 08:56 PM
Hey Guys,
It is -17 outside but I have to get my ass in gear. My xr650r motard seized in december and now I'm taking the engine out. I followed the manual to the last detail. Right now, the engine is just sitting in the frame and swingarm. All bolts are off. I tried pulling the engine out and I couldn't budge it. Shaking and swearing didn't work either. The manual just states lift and pull the engine through the right side. Easier said then done.
I'm alone doing this maybe I should call someone for help. I sprayed the crap out of the swing arm and engine points(where it touches)with wd40. Now I have to see if that helped. It seems that there is so little amount of clearance at the points where the swingarm/engine/frame are aligned..
My question is ...is there a trick to this?
Thanks
Lubos
  • thouk
Posted February 04, 2007 - 11:50 PM
The swingarm has a bolt that mounts through the engine also. If you don't have that out the engine will not budge. I hope that helps, Tony
  • stoneagegixer
Posted February 05, 2007 - 01:27 AM
The last step on the engine removal is to remove that bolt. states: remove the swingarm nut/bolt.
That I did but the engine is so snug in there, I can't budge it. If I pull on the swing arm, it will come out (probably) and the whole front might fall over. With the engine just sitting there, I don't want anyother broken bits....
  • 3 replies
  • 4 replies
  • 17 replies
  • Hot  35 replies
  • 22 replies
