Won't Start
10 replies to this topic
  • TheRainMan
Posted February 03, 2007 - 08:46 AM
Hey All,
Got an 02 426 thats been running great for about a year now. Was out riding last weekend and I stalled the bike in a turn, now I can't get it to start. I changed the plug and it still won't start and checked that the carb is getting fuel. Any suggestions (ignition coil, CDI, etc.....)????
Thanks
  • tammie
Posted February 03, 2007 - 07:05 PM
one time my yz400 wouldn't start for no apparently reason, I unbolted the ignitions coil, cleaned the ground connection and put it back on and viola fired right up the ground must have come loose or got dirt in it.........just a suggestion.....did you check ur valves? timing chain?
  • TheRainMan
Posted February 03, 2007 - 07:19 PM
I'll try unbolting and cleaning the coil/contacts and see what happens.
Haven't messed with the valves or timing yet....still trying simple fixes.
Thnx!
  • 642MX
Posted February 04, 2007 - 03:52 PM
Have you verified the spark?
  • new2blu
Posted February 04, 2007 - 08:09 PM
Check for spark--if no spark maybe the kill switch is the problem(unplug it may fix problem). If spark is ok check to see if fuel is getting into engine. If fuel is ok then check the valve clearances.
  • TheRainMan
Posted February 08, 2007 - 12:46 PM
Wow Crazy!! Changed the spark plug twice, checked coil, checked spark.
While checking the spark I kicked the bike over about 20 times put the second new plug in and it started on the 2nd kick. No idea what changed but for now it's starting (doing the happy dance)!!!!
  • TheRainMan
Posted February 08, 2007 - 12:50 PM
Also, I just ordered the 03 YZ450 exhaust cam for the MOD. Got one Yamaha dealer here in Albuquerque that swears it won't work and I got the other dealer here saying they have'nt done the MOD before. Not sure if I should do it myself or try the second dealer.
Posted February 08, 2007 - 01:04 PM
You have the instructions, right?
http://www.thumperta...078#post3706078
  • King_Air
Posted February 08, 2007 - 03:12 PM
There is lots of infomation in the link that Grayracer gave you. Spend some time reading that thread to make an informed decision. I am doing it myself this weekend. If you have some mechanical ability and correct tools available I think you could do this mod.
  • gildnernorth101
Posted February 08, 2007 - 07:16 PM
Sounds Like Your Valves Arnt Seating Try A Compression Test
  • TheRainMan
Posted March 01, 2007 - 02:03 PM
Thanks everyone for all the help,
Got tired of the starting drill and had a local dealer install the OEM cam. Just picked the bike up today and it starts on the 1st kick. Can't wait to take it out for a ride!!!!!!!!!
  • Hot  36 replies
  • 5 replies
  • On January 15, 2017
  • Hot  113 replies
