06 clutch
4 replies to this topic
  • kylwk1500
Posted February 02, 2007 - 02:50 PM
I am planning on putting in a new clutch kit soon.
just looking for some suggestions on prep and instalation of the plates.
  • tonto256
Posted February 02, 2007 - 02:57 PM
GYTR kit for about $110. Spread some oil on the fibers before you install them and put the machined side of the steel plate facing out from the motor. If you have a Hinson basket and inner hub, don't run the inner anti-chatter ring.
Posted February 02, 2007 - 07:59 PM
GYTR kit for about $110. ... If you have a Hinson basket and inner hub, don't run the inner anti-chatter ring.
Why do you say that?
  • tonto256
Posted February 03, 2007 - 08:17 AM
When I installed my Hinson unit there was a note about not using that part. I called them and they said it is not necessary to use the inner spring (which is an anti-chatter spring) because their basket/inner hubs don't have a chatter problem. Call Hinson and they can give you more info. GYTR plates and Hinson components is as good as it gets.
  • TeamScream
Posted February 05, 2007 - 09:00 AM
Also if you don't run that anti chatter ring, get yourself one more friction plate to replace the little thin friction plate.
The thin friction plate is designed to be used with the anti chatter ring but if you toss that ring out, then you can run a full size plate as the very first plate you install.
Look closely at the plates and you will see what I mean.
  • Hot  28 replies
  • On January 15, 2017
  • Hot  113 replies
  • Hot  47 replies
  • 10 replies
