my first thumper
12 replies to this topic
  • Type Gendy
Posted February 02, 2007 - 12:14 PM
I recently bought my first 4 stroke, an 01 426. I bought it from a friend who bought it from the original owner in the fall. I'd like to have this thing ready to ride in the spring (if i ever learn to start it).
While i dont know much about this bike, except that it was claimed to have only been ridden 2 seasons and do a lot of sitting.... what else should i do to it besides an oil change , plug, and getting her lubed up?
  • jayh300
Posted February 02, 2007 - 12:34 PM
nice bike and welcome.....
learn the starting procedure , many posts on that here
get a good manual on it, the maint is different.
I would change all fluids
don't ride it slow or let it idle for very long as they will overheat. everything you will need to know about that bike is on this site.
great bikes love mine
  • Reyndogg
Posted February 02, 2007 - 12:41 PM
IMO you should get a fork brace...
good luck,
  • buzzgrizz
Posted February 02, 2007 - 12:52 PM
Welcome, Just get the "starting procedure" down and have fun.
Nice looking bike.:ride:
  • skipperlantz
Posted February 02, 2007 - 05:53 PM
Check all of your fluids and lube areas. That bike looks clean in the picture. Learn to use that compression release to start it and you'll be in Heaven! Besides an XR, my 2000 was the most reiable bike I ever had.
  • Jaycycle
Posted February 02, 2007 - 06:25 PM
Cool man, welcome! Have fun with her.
  • yama02yz250f
Posted February 02, 2007 - 06:43 PM
you should do the 03 cam mod. It gets rid of the starting procedure. ALl you do is kick. I did it on my 250f and now my dad wants me to do it to his 00 426
  • Type Gendy
Posted February 02, 2007 - 10:55 PM
Why should i get a "fork brace" ?
HOw about the timing chain on this thing, is that something that should be checked for tension / wear?
  • PATHPOUNDER
Posted February 03, 2007 - 06:33 AM
Hes talking about sticking something in between the tire and fender when you tie it down so the forks dont compress too far...I use a piece of 2x4 around 10 inches, works fine...
If the timing chain hasnt been changed on an 01 426 , change it..Its wore out and stretched...This is the connection to the top end from the lower end,keep it fresh...Change it every 100 or so hours....A chain jumping the teeth can grenade an engine costing you up to 1500.00....55.00 cam chain, change it..
BTW.....Nice looking bike ,the 426 is a great machine..
  • Type Gendy
Posted February 08, 2007 - 10:11 AM
Thanks guys. I gotta do a search on what oil to use for this. I went to yamaha yesterday and spent $47 on oil and a filter :censored: They said to use some special 20w-50 semi-synthetic thumper oil, sounds like a crock of shit?
  • 642MX
Posted February 08, 2007 - 10:54 AM
Thanks guys. I gotta do a search on what oil to use for this. I went to yamaha yesterday and spent $47 on oil and a filter :thumbdown: They said to use some special 20w-50 semi-synthetic thumper oil, sounds like a crock of shit?
$47 for oil and a filter. :ride:
Buy a K&N 142 oil filter (its brass and can be cleaned/reused) and stop by Walmart and buy a gallon of Shell Rotella 15W40. $9.00 filter and $8.00/gallon of oil. :censored:
Posted February 08, 2007 - 11:37 AM
OK, so why did they charge over $25 for an oil filter? That's where the problem is. The most you should have paid for the "special" oil is $11/qt (still too high, but I've seen it), and I figure you got two, so that's what's left.
My solution is the Scotts stainless steel oil filter, which is reusable indefinitely, and Amsoil MCF for under $8/qt, true total cost. Mobil 1 MX4T is another excellent oil, but it's often overcharged for (should be $8/qt).
You can get cheaper oil, but none that are as good for less than that that I know of.
  • King_Air
Posted February 08, 2007 - 03:19 PM
Try a search on scotts oil filters and have fun reading. Here is one to start with. http://www.thumperta...otts oil filter I do not trust cleaning the brass mesh ones. Too much risk of enlarging the screen holes. I use a Scotts stainless steal. Well worth $ 70.00 for my piece of mind.
  • Hot  47 replies
  • On January 15, 2017
  • 10 replies
