Hardware for Acerbis 6.3 Gallon?
2 replies to this topic
  • brp2004
Posted February 02, 2007 - 09:57 AM
I bought a used tank on ebay for my 650r and it came without hardware. Anyone have this hardware around, or a photo of what the hardware should look like?
  • ganshert
Posted February 02, 2007 - 02:30 PM
http://trailpilgrim....?t=1071&page=15
post #150
you will have to come up with a suitable replacement as Acerbis doesn't sell a hardware kit seperately from the tank
I wanted to get the radiator braces from them which is how I found that out.
you can use the stock upper hardware
the front holes on the tank mount to the front lower radiator shroud mount points. You will need 4 rubber spacers about 1/4 to 3/8ths of an inch thick and 1 inch or so in diameter, 4 large washers the same diameter as the rubber spacers, and bolts long enough to go through the whole assembly.
it goes bolt-washer-rubber-tank-rubber-washer-bike on both sides.
good luck
  • brp2004
Posted February 03, 2007 - 09:51 AM
Thanks for the info.
Honda XR650L 2017
  • 0 reviews
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 22 replies
