2005 XR650R Suspension
10 replies to this topic
  • TINYSC51
Posted February 02, 2007 - 09:52 AM
Hello,
I have an 05 XR650R with stock suspension. It is definately too soft for me, as I weigh 260lbs.
What is the best way to re-do the suspension? I know I will need stiffer springs.
What company makes the best springs? What company is the best right now?
About how much will the whole project cost?
Thanks in advance,
TINY
  • abby
Posted February 02, 2007 - 10:46 AM
Hello,
Thanks in advance,
TINY
I'm in the process of re-springing mine (05 XR). I come in around 300 geared up. I got front/rear Eibach springs (.49 kg/mm front and 12.0 kg/mm rear from Factory Connection in New Hampshire, about $220.00 shipped to me. Got them in 4 days.
Doing the labor myself (it's really easy). Not revalving yet, going to just try the springs first.
  • willnevergrowup
Posted February 02, 2007 - 11:55 AM
I am doing the same as abby and already have my Eibach springs and revalve later if needed. Here is a link for some used ones.
http://www.advrider....ad.php?t=200647
Hope this helps!
Elmer
  • Bigmutha
Posted February 03, 2007 - 08:35 AM
I just changed the springs. Race Tech in front and Eibach in back. What a difference. Cost was $200. I am 260lbs.
  • MindBlower
Posted February 03, 2007 - 11:33 AM
What rate eibach did you get? Was just at Race Tech site and they didn't show anything higher than a 9.0 even for 260lb. Another site says that would take a 11.-12.0 spring. What's up with that?
  • drex
Posted February 03, 2007 - 12:27 PM
Check out Bruce's site for the info:
http://xr650r.borynack.com/
  • Crunchy
Posted February 03, 2007 - 05:29 PM
Hope this helps!
Elmer
The set in that link are actually new (that's my post:thumbsup: ). An 11 rear and a set of .47 for the front. Also included is a rear shock assy from an XR650R that is in very good condition and ready to send off for revalve. I was asking $150.00 for everything + shipping costs.
  • Thumpmeister
Posted February 03, 2007 - 07:36 PM
This is the exact same setup I have. Once you get the drag set right, its great. I didn't have a spanner wrech that worked well on the rear shock, so once I got one, I was able to tighten it down, and it works REALLY well now. I clock in at about 265, so it works well for me. Since I did the kritter fix on the right footpeg, the little arm on it is bending now, though. So, thats kind of annoying, but at least the suspension works well!
  • MindBlower
Posted February 03, 2007 - 10:56 PM
I want this!!
  • TINYSC51
Posted February 04, 2007 - 01:20 PM
What was the size of the springs that you got?
  • TINYSC51
Posted February 04, 2007 - 01:27 PM
Hope this helps!
Elmer
Do you still have the front and rear springs for sale?
