Does a rear rim fit both 250 and 450?????
4 replies to this topic
  • PAdaytonaman
Posted February 02, 2007 - 05:49 AM
I need a new rear rim for my 450 and saw one on ebay that came off a yz 250 2 stroke. Will that fit on my 450 f 2006.
  • YZ426F Rider
Posted February 02, 2007 - 06:42 AM
I'm pretty sure that YZ250/250f/400/426/450 from '99 on have the same rear wheel. Same thing with the front.
  • Yamahafan
Posted February 02, 2007 - 06:51 AM
Normally I would make you look this up yourself, but since your ground hog predicted an early spring this morning, the answer is YES.
According to the Thumpertalk parts diagram, the YZ250 and the YZ450F share the same rear hub from 1999 - 2006. I am pretty sure 2007 works as well, but it is not up yet.
2006 YZ450F Rear Wheel
2003 YZ250 Rear Wheel
Posted February 02, 2007 - 08:45 AM
Double check the rear wheel spacers. IIRC, they're different between '03 and '06. There's another set for earlier bikes, like the '01. Otherwise, the rear hus are the same, and the front wheel/axle/spacers interchange directly.
Also check the rear rim width. The 450 should have a 2.15 rim. I believe the 250 2-stroke does as well, but the 125 and 250F use a 1.85.
  • PAdaytonaman
Posted February 02, 2007 - 04:58 PM
Very Funny re: the groundhog. Shorter winter means more riding right??
Thanks for the replies, very helpful.
  • Hot  33 replies
  • 5 replies
  • Hot  106 replies
  • Hot  36 replies
Need help by Goforaride
  • Hot  68 replies
