Air Fuel Screw washer question
5 replies to this topic
  • Fryboy
Posted January 31, 2007 - 07:29 PM
Hi WR guru's,
I am wondering if you were missing the washer, not the spring or o-ring, what would be your likely symptom (s) ?
Thanks for you help
  • Team_Oatmeal_Pie
Posted January 31, 2007 - 09:47 PM
Complete Engine Failure, If I where you I wouldnt even start it...........
Good to see some of the old guard is still around. Any idea what happend to the rest? My guess is they either quit riding or went Orange.
  • Fryboy
Posted February 01, 2007 - 10:32 AM
No one has any idea? I have lost the entire fuel screw once, and my bike wouldn't idle at all. I guess what I am getting at, is,
do you think not having the washer could be causing a too lean condition, in turn, causing hard starting? This is assuming your Carb is clean and your Valves are in spec.
Give me something guys !!!!!
Nice to hear from you Team Oatmeal :ride:
  • cumminsgetsome
Posted February 01, 2007 - 11:07 AM
I don't think it does much more than just keeping the spring off of the Oring.
  • new2blu
Posted February 01, 2007 - 12:46 PM
I believe that the washer protects the oring from being damaged when the fuel screw is turned.
  • JimL
Posted February 01, 2007 - 04:26 PM
I think it could be rich or lean. without the washer the spring can cut the o-ring and push it to the side or push it into the hole and block it. Call sudco , you can order the washer and o-ring from them. Yamaha makes you buy the whole fuel screw assembly to get what you need. I ordered 5 of each after I searched my garage for an hour one night.
