leaking Petcock...
11 replies to this topic
  • toofazt
Posted January 31, 2007 - 06:55 PM
Any one have a part number on the seal for the petcock? Mines leaking where the lever is. There are two little screws that look like I can take off and replace the seal? Anyone have any info? Thanks, Steve.
  • Ga426owner
Posted January 31, 2007 - 07:15 PM
yea I went thru this - replace the entire petcock and with new gasket....I tried to piece it the cheap way and it still leaked...15-20 bucks
  • Butta
Posted January 31, 2007 - 07:20 PM
I'll second that!! I tried to do that on my XR650R as well, because the petcock for it was over $50!!!! But in the end for a Yamaha, it's just easier and quicker to replace the whole thing.
  • toofazt
Posted January 31, 2007 - 07:46 PM
So a new petcock from the dealer is only $15-$20? Is there a gasket or seal behind the lever?
Posted January 31, 2007 - 10:08 PM
You'll need one each of the following:
17 3AJ-24534-00-00 .SEAL, FUEL COCK
19 4X8-24512-00-00 .O-RING
20 3AJ-24523-00-00 .VALVE PACKING
As Ga426 pointed out, your results may vary.
  • toofazt
Posted February 01, 2007 - 12:07 AM
Cool, thanks a lot grayracer513! :ride:
  • Goosedog
Posted February 01, 2007 - 05:26 AM
You might want to concider the WR petcock. Same money, bolts right in and then you've got reserve.
  • King_Air
Posted February 01, 2007 - 07:29 AM
I too had no luck with repacking the petcock. Ended up buying new. It would never shut off with the new seals or the old seals. New on worked great and was fairly cheap.
  • Ga426owner
Posted February 01, 2007 - 07:32 AM
I 2nd and 3rd this....don't waste your time....
  • toofazt
Posted February 01, 2007 - 04:49 PM
Bought a new one for $20 :ride:
  • olschl
Posted June 25, 2007 - 08:22 PM
Link to where you bought it please..
  • King_Air
Posted June 26, 2007 - 03:15 AM
I got mine from the dealer around $20.00. The thumper talk store has them also for less.
  • Hot  47 replies
  • 0 replies
  • Hot  36 replies
Motocross
  • Hot  491 replies
