XR650R Head and Taillights
9 replies to this topic
  • pman13
Posted January 31, 2007 - 08:17 AM
I've upgrading the lighting on my 2000 XR650R, because I ride it to work (when its not winter) and I can outride the stock headlight in first gear. I bought a Ricky's Stator and I'm about to install it so I now have the power to run a brighter light, but I'm not sure which light to run. I know I can just swap the bulb, but does anyone have pics with different head lights (like acerbis)? What about tail light setups? I'm going to get some LEDs for my license plate so someone might actually see me from behind.
Thanks.
  • Red_Chili
Posted February 01, 2007 - 09:02 AM
I like these, particularly the Edge 2:
http://www.wheelingc...&cat_id=72#2186
Be sure to silicone it and seal it up well. Small, light, bright.
I also fitted an LED 1157 replacement in the stock taillight housing. Can't have too much brakelight on the road. Used epoxy gell to affix the base to a UFO fender (no screwholes). Glued the snot out of the shrinktubed light harness where it perforates the fender too, so it should stay put.
I also run a UFO Kawi/KTM-style headlight because I like the looks, but I don't think they are made anymore. A downside is the light is low which the front fender tube bag kinda interferes with. 55/60W Hi/Lo H4 running off a B-D rewound stator, the regulated AC side. Could run 80 or 100W if the mood struck me, and it just might after riding a cold dark commute the other night.
  • HawkGT
Posted February 01, 2007 - 10:21 AM
I run a Baja Designs 8" halogen headlight and a Baja Designs LED tail light, brake light, liscense plate holder combo. I've been very happy.
  • jesusgatos
Posted February 02, 2007 - 11:54 AM
Do you run that BD headlight on the street? Can you get one of those with a hi-low beam or maybe put a dual-filament bulb in there?
  • HawkGT
Posted February 03, 2007 - 09:05 AM
Yes I do run it on the street. I run a single fillament bulb--not sure what's available.
  • MindBlower
Posted February 03, 2007 - 11:40 AM
I've been thinking about that combo taillight setup myself. Can you post a pic of it? Would REALLY like to see one on. Does the Edge 2 need a resister or anything to hook up?
Th
  • jesusgatos
Posted February 03, 2007 - 11:54 AM
Does it seem to affect or bother other drivers? Any problems with law enforcement? Can you run that light with the stock stator? Sorry for all the questions, just very interested in running something like that myself.
  • InternalCombustion
Posted February 03, 2007 - 12:38 PM
Like HawkGT I also got a Baja Designs LED tail light, brake light, liscense plate holder combo, but for the wife's crf230. Sweet looking, bright unit.
I wished I'd used it on my 650r. 3 years ago I bought a now-discontinued E-Line dual sport kit for my 650r. It looked super slick but the electrics turned out to be pretty much a POS. Had to change out all the switches and the headlight reflector assembly (replaced that with a BD glass lens with an H4 bulb).
I did my own stator rewind on my R and have about 125w available. I'm running a PIAA SuperWhite 60w/60w H4 bulb in the BD glass lens in the front housing of my R. Real happy with the light output.
Whatever you get for the front make sure it uses an H4-type bulb and not some weird bulb type. H4 allows you a lot of flexibility in wattage.
My two cents.
  • HawkGT
Posted February 03, 2007 - 05:32 PM
I run a 55w bulb with the stock stator. The beam is adjustable on the fly for "high" and "low", so to speak. The whole reflector housing pivots up/down and cinches with an easy reach knob. With the angle adjusted for street riding I don't think it bothers anyone--same as any other motorcylce headlight.
here's a thread I started a while back when I started thinking about an 8": http://www.thumperta...ad.php?t=381154
  • motopsycho650
Posted February 03, 2007 - 07:35 PM
Rear: I bought 2 9-LED bulds that fit in an 1157 socket. I had a 1157 socket from the old Baja Designs brake light kit. The LED bulbs are not near as bright as a normal light bulb. So, I tore out the socket, and rigged both bulds in the rear lens side-by-side. One buld has both filiments working as a running light, and the other has both filiments as a brake light. This works much better.
Front: I bought a "Stock lighting upgrade kit" from Baja Designs for 40 bucks 3 years ago. It is actually a Honda part #. It consisted of a glass lense for better optics, and a 55 watt PIAA Super White H3 buld. With my re-wound stator, this produces a LOT of light. Very happy with this mod.
  • 22 replies
  • Hot  60 replies
  • 4 replies
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
