New Drive Train
4 replies to this topic
  • 127
Posted January 30, 2007 - 09:58 AM
So my stock chain sucked and I bought a DID but I rode it with too much slack - now my rear sprocket is junk
I'm told that I should buy all 3 compenents together.
I was thinking Renthal 13 and 49 with a DID chain... any thought?
  • sean3239
Posted January 30, 2007 - 10:08 AM
I am sure you will get a lot of combinations that people like on here. Myself, have Renthal R1 Gold and two wheels I switch out depending on tread and flats. One has a Renthal 50 and the other has a Sunstar 50. They both are holding up well after about 6 months. The Renthal sprocket surprises me because its aluminum yet the teeth look great. I think the key is alignment and slack! Miss either one and :ride:
Posted January 30, 2007 - 10:24 AM
You just bought the chain, and I'll assume it's a high grade DID. If it has not been on the bike long, measure the chain to detect stretching. There are two ways of doing this:
> Using a vernier caliper, measure several sections of the chain by measuring from the inside edge of one roller to the inside of the eleventh roller down the run. The manufactured length is 5.85" when measured this way. The manual states the wear limit is 6.0", but in your situation, where you intend to use it on new sprockets, you should reject it if you find any of the several sections checked to be more than 5.9".
> Lay the chain out on the floor, and count out 101 pins. Measure between the two pins at the ends of this 101 pin set. The original length would be 62.5", and you should reject it at 63.125".
I have replaced a number of worn rear sprockets while reusing the chain and front sprocket. It depends on why the sprocket is worn, and on the actual condition of the other two components used as to whether they should all be replaced at once.
Posted January 30, 2007 - 10:30 AM
I ...have (a) Renthal R1 Gold (chain)
And an excellent chain it is. But you should know that it's a Regina ORN6, and the Regina is about $20 less expensive.
  • sean3239
Posted January 30, 2007 - 10:34 AM
Wow! that's quite a % difference. Thanks, I have had good luck with that chain so I will look for the Regina from now on.
  • 9 replies
  • Hot  36 replies
  • Hot  47 replies
  • Hot  50 replies
