Sticky Throttle Cables
2 replies to this topic
  • M_HELD250
Posted January 30, 2007 - 07:09 AM
I Have A 04 Yz450, And If I Let It Sit For A Couple Of Days, The Throttle Gets Stuck Wide Open. I Have Tore Apart, Cleaned And Lubed. After A Couple Days It Will Do It Again. Does Anyone Have Any Suggestions?
  • tammie
Posted January 30, 2007 - 07:13 AM
did you check in the housing at the carb where they attach there? they may be frayed, my cables have frayed there and almost have to replace them every winter!! I have a yz400 but you might have that problem.
  • PAdaytonaman
Posted January 30, 2007 - 07:17 AM
Ditto on the linkage in the carb, also check your free play at the grip. Too tight will prevent return, should be 3-5 mm.
  • 5 replies
  • Hot  79 replies
  • Hot  36 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • 0 replies
