Fork Seal
6 replies to this topic
  • DAVID146
Posted January 27, 2007 - 07:12 PM
I have been having trouble with my front fork seals on a 06 450. I am on my third set in 2 months. I understand from my Sup guy, that the seals the oem are useing now have a lesser retaining ability due to the larger forks and the after market quys have not got a handle on it yet for the 06 07 models. So we are back to oem on the third set all under his warranty. Does anyone have a solution?
  • 02YZ426
Posted January 27, 2007 - 07:27 PM
I just put a set of factory connection seals in my 06 and they seem to be a much tighter fit than oem. What other seals have you tried aftermarket?
  • Scooter33
Posted January 27, 2007 - 07:40 PM
Usally this is a sign that you need new bushings, but the bike is so new that shouldn't be the case. The next time you change them I would check the bushings just in case. If your a bigger guy you could try a little bit heavier weight oil. 5w will find its way out easier than 7.5 or 10.
  • bluerider31
Posted January 27, 2007 - 07:52 PM
Put seal savers on next time. I have had my bike over a year now and never had any leaks.
Posted January 27, 2007 - 09:09 PM
The OEM seals are not impressive looking. Read:
http://www.thumperta...938#post4273938
If this fails to hold up well, I'll look into Synergy Seals.
Be sure to critically inspect for any vertical scratches or nicks that you can feel with a fingernail. Sand them out in a cross hatch pattern with 320-600 grit wet/dry. Failure to do so may cause a repeat of the leak.
  • cappy79
Posted January 27, 2007 - 09:11 PM
do the factory connection seals cause too much friction/stiction? I remember some aftermarket seals in the '70's that actually slowed the forks down? Husqvarna used to say a little weeping was good for fork action. Just wondering
  • Ga426owner
Posted January 28, 2007 - 08:49 AM
Bingo...maybe this is what Yamaha was thinking with the oem seals..:ride:
Synergy or FC are the way to go in my opinion..unless you like swapping seals every 5 or 6 hrs:excuseme:
