07 Suspension for HS?
4 replies to this topic
  • George_Felix
Posted January 27, 2007 - 07:25 AM
I know I've seen comments buried in other threads but I was wondering what would be a good starting point considering positive comments on the stock set up. Or would you recommend a re-valve? If so, front and rear?
I'm 170 lbs without gear. Intermediate rider.
Thanks for your help....
  • Supafreak_711
Posted January 27, 2007 - 04:03 PM
Check out this link off of motoman393's website. Hope it helps.
http://motoman393.th...suspension.html
It was written with MX in mind, but I bet you could take come good information from it.
Posted January 27, 2007 - 05:22 PM
You should try it as is. The OEM suspension is among the best as is.
If you find it harsh, try removing 5cc at a time from the outer chamber of the fork. If that hasn't done it for you by the time you've dropped 20cc a side, consider lowering the spring rate a step. I would doubt revalving would be needed.
Read the setup guide linked in the post above, too.
  • howard27
Posted January 29, 2007 - 10:52 PM
My 06 was revalved / resprung and works great but I dont use the bottom 1 1/2 of suspension . Do you think I should start at removing 5 cc of oil or should start with 10 cc ?
Posted January 30, 2007 - 09:18 AM
You could try 5cc (MXA thought 10 would do it for them, but they were surprised at the effect it had, and ended up adding 5cc back)
Are your new springs stiffer or soifter than stock?
  • 10 replies
  • Hot  47 replies
  • Hot  30 replies
  • 3 replies
  • Hot  28 replies
