Starter spinning backwards
2 replies to this topic
  • onelugnut
Posted January 25, 2007 - 06:16 PM
I had to replace the left side cover.While it was of I took off the starter and took it apart to inspect it.After I put it all back together it looks like it is sinning backwards:cry: What have I done.:ride:
Posted January 25, 2007 - 06:28 PM
Did you by any chance rotate the center section of the starter (the part with the magnets) in relation to the end cap with the brushes? The magnets need to be oriented correctly or it will turn backwards. If so try rotating the center section 180 degrees.
  • onelugnut
Posted January 25, 2007 - 06:31 PM
Thats got to be it.Thats BPDBLUE
