just bought a used 06...a few questions.
9 replies to this topic
  • yzfmxer
Posted January 25, 2007 - 10:11 AM
I have all of the plastics, tank, subframe, shock taken off. what are all of the things I should look for, check ect...
I just got it yesterday. it has a few goodies on it:applause: Vortex ignition, windham protapers, asv levers and perch, FMF Ti 4.1 with mega bomb header, extra set of excel wheels all laced up with rotors and sprocket, extra stator, clutch, 3 oil filters, engine gasket kit ( just incase), protec kickstarter. And all of the stock stuff he took off. I feel like I got a good deal for $5000. Its wasnt ridden much. I cnat wait to ride it!!
  • WFOracer
Posted January 25, 2007 - 10:25 AM
Check your valve clearances...just to get an idea if they are in spec and to establish a baseline.
Grease the linkage and headset.
Sounds like a good deal with all the goodies!
  • Baron Von Beard
Posted January 25, 2007 - 02:15 PM
Basic maintenance stuff, like greasing wheel bearings, linkage, headset, lube cables, clean throttle assembly, etc. Treat it just like a new bike even though it's used. You want to catch anything that needs attention before you are out riding it and it becomes an issue.
I think you got a great price on it as long as it's in good shape. Nice buy!
  • Reyndogg
Posted January 25, 2007 - 02:43 PM
Ill 2nd (or 3rd .. whatever) greasing the bearings...I've only got about 70hrs on my 06 and ive had to do the steering stem bearings five times already - seems like the seal doesnt seal too well.
Good luck
  • Smokeslider
Posted January 25, 2007 - 08:37 PM
Ditto all of the greasing, they didn't really come with much, set your sag, and Have fun!!
  • red7
Posted January 25, 2007 - 11:21 PM
Just out of curiousity, how do you know when you need to regrease the bearings, headset and how do you do it?
  • Reyndogg
Posted January 26, 2007 - 06:56 AM
You can feel (at least i can) when the bars start to get harder to turn or feel kinda gritty when I turn them if that makes sense? Anyway, this is especially true when it's in the garage and on a stand.
here's the steps I use:
http://www.transworl...1012822,00.html
  • yzfmxer
Posted January 26, 2007 - 09:18 AM
Thanks for the info, the headset must have been greased recently, there was still a little blob of grease on the top of the stem where the big nut is. it was the same way with the axels. I think he was good at greasing. i will check the linkage though.
  • red7
Posted January 26, 2007 - 09:35 AM
Thanks for the link, that's exactly what I was looking for!
  • Reyndogg
Posted January 26, 2007 - 10:47 AM
:ride:
You may want to save that page in case twmx takes it down.
  • Hot  38 replies
  • Hot  50 replies
  • Hot  36 replies
  • 0 replies
  • 5 replies
