Radiator Replacement
3 replies to this topic
  • Dognut
Posted January 24, 2007 - 03:17 PM
Just wondering if there is a need to bleed the radiator after replacement to prevent air pockets?
Thanks Damo..
  • johnnyjeep
Posted January 24, 2007 - 06:17 PM
I could be wrong, but after a couple hot/cold cycles you should be ok. Im only talking from XJ expierence, i would think with the recovery tank even these small cooling systems would be fine
  • JRAMBO
Posted January 24, 2007 - 07:08 PM
I did not Do that to mine I just filled it ran it a couple times and check the fluid it was fine refill if needed.
  • johnnyjeep
Posted January 24, 2007 - 08:31 PM
Kind of what I said...
