Ultimate XR650L
21 replies to this topic
  • Motosprtman
Posted January 24, 2007 - 01:05 PM
did anyone see this on ebay
http://cgi.ebay.com/...1QQcmdZViewItem
  • flyin vee
Posted January 24, 2007 - 02:42 PM
Nice ride, he claims that it has 50 hp. Is that possible with that engine?? If it is, how much reliability would be sacrificed?
  • oldchvytrx
Posted January 24, 2007 - 02:58 PM
I'd say it is quite attainable as I had a 74 XL250 engined short track bike dynoing 42 hp without the benefit of some of the technology this guy had available.
With the stout construction of the L's engine I think it would still be quite dependable.
Makes me want to dyno my "new" 676 and see what it's got?
:ride: :ride: :ride:
  • lrutt
Posted January 24, 2007 - 03:13 PM
doesn't list a cam. Either it's BS as you would not get 50 without a cam, or he forgot.
  • XR650L_Dave
Posted January 24, 2007 - 03:43 PM
This guy is known on 4strokes.com, he's not seen as a BS'er.
Don't know if he dyno-ed it or not.
Dave
  • bigredxr
Posted January 24, 2007 - 06:05 PM
All of Matt's work was done by xr's only and I'm sure it makes the power he says it does! Be careful what u say when u don't know the facts!
  • danbart
Posted January 24, 2007 - 10:06 PM
I doubt anyone will ever pay 10K for an XR650L, no matter how many mods it has!
  • bigredxr
Posted January 25, 2007 - 03:23 AM
Bike was listed for 5999.99 buy it now price on fleabay and is sold! I guess your right nobody would pay 10k for a xr650l.:ride:
  • MindBlower
Posted January 25, 2007 - 04:58 AM
It IS listed for 10000.00 buy it now price on ebay.
Guess maybe YOU should look before you flap. :ride:
  • nxridge
Posted January 25, 2007 - 05:00 AM
I dont see anyone jumping to any non fact conclusions .
i think the 50 hp
was posed as a question as if it was possible to obtain that much power with the 650l engine. no one was doubting the posters specs.
  • Motosprtman
Posted January 25, 2007 - 06:04 AM
so! how many HP do you get by simplying uncorking it 2? 3? 5? just curious. I know the motor sounds happier especially cold!
  • mgs781
Posted January 25, 2007 - 06:37 AM
Any hp claim without a dyno sheet is B.S., assuming that the mods produced more hp is speculation. It does seem reasonable that the work would produce more power, but again where is the proof?
I think my L has 50+ hp with more work done than this guy, but until I get it on the dyno nobody knows. I can tell you for a fact that my bike will walk all over a stock or uncorked L, it has been done.
MGS
  • danbart
Posted January 25, 2007 - 07:47 AM
MGS
How does your L run compared to an R?
  • whodis
Posted January 25, 2007 - 08:24 AM
if you pay attention to ebay there is alot of BS in the auctions.
  • mgs781
Posted January 25, 2007 - 08:57 AM
The R has more lower end and will pull hard from down low.
The Hotcams or any performance cam changes the way the engine revs, more duration and lift which make the engine breath better in the upper rpm range. A stock engine has tons of low end, but runs out of steam up top.
I would expect a high compression ratio engine with the stock cam to have tons of grunt but similar poor high rpm performance. The valve job will help, but 3 angle valve jobs can't compensate for a good performance cam.
I ride alot with a guy that has an un-corked R. The motor is a beast. My bike hits softer down low but revs out in a similar way. With that said, I am never more than a bike length behind. He is also a better rider than I am.
MGS
  • danbart
Posted January 25, 2007 - 11:22 AM
Nice! Thanks.
I've got an 03 XRR that I love, but alway have the XRL bug in the back of my mind. I love the simplicity of the L, the e start and =the descent rear rack subrame for dualsport stuff.
I'm just affraid that after the XRR I'll be disappointed by the XRL.
Later Dan
  • asf
Posted January 25, 2007 - 11:37 AM
kingtutt is on the 4strokes forums and knows his stuff, and definitely put some time into that bike.
I am not going to say anything about the numbers but even with a dyno sheet all dynos run differently, the only thing a dyno is good for is to get a relative number the actual number is irrelevant.
Also, wheel HP or crank?
He is not the guy who goes around spewing BS, and yes his bike is already sold.
  • mgs781
Posted January 25, 2007 - 11:59 AM
Dyno numbers are very relevant and properly setup dynos are accurate.
The problems is that most dyno opperators don't have the skill or understanding of the equipement to take an accurate measurement.
Horsepower measurements should be made under very controlled conditions and should be corrected for humidity, altitude, and air temperature.
Dynos can be made to read high or low depending on these variables.
I guess everyones point is that the claim was made with substanciating evidence.
In addition, I thought all the engine work was done by XRs Only not the owner. If they said 50 hp, then it is probably true, they have done enough of them. Bolting components onto a bike does not make anyone an engine tuner.
MGS
  • mgs781
Posted January 25, 2007 - 12:49 PM
I forgot one thing, the ultimate XR650L is right here:
http://www.thumperta...achmentid=13913
Nothing stock!
MGS
  • asf
Posted January 25, 2007 - 12:53 PM
People are saying to post dyno numbers to prove that the bike has the HP it does. Or say that my bike makes more power than yours. But you cant do that with a dyno sheet. That was my point exactly, numbers are not accurate. So it is the relative increase that matters. Even if you got a dyno sheet saying 55 HP on dyno 1, it may ready 50 HP when you take it to dyno 2, making all dyno numbers not performed onthe same machine by the same tech apples to oranges...I really dont see how comparing apples to oranges makes a number relevant.
Like I said I'm not going to say anything about the numbers, because I don't know (and the ad just says sold on it). But between the shop that did the work having seen enough of these and a pretty careful enthusiast who knows his way around a wrench I'd be surprise if that was just a random number out of nowhere. Then again, I;ve been wrong before and will be wrong again....:ride:
One thing is fore sure, you've got a pretty nice L
  • 4 replies
  • 22 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • 9 replies
Honda XR650L 2017
  • 0 reviews
