How the hell does everyone do this?
18 replies to this topic
  • theclone
Posted January 23, 2007 - 06:44 PM
By "this" I mean adjusting the fuel screw. I know what it is and what it does, I just can figure out how I'm actually supposed to adjust this thing. I never got around to buying an aftermarket fuel screw and I dont want to now because I'm selling my bike soon. So whats the best way to do it?
  • John407
Posted January 23, 2007 - 06:54 PM
I had to loosen the carb and rotate it so that I could get at the fuel screw. I never had a screw driver that would work. The aftermarket fuel screws are a very good idea.
  • Baron Von Beard
Posted January 23, 2007 - 06:56 PM
Uhhhh, you said you don't want to know but then immediately ask how to do it...
There are a bazillion posts on how to set you fuel screw. Do a search.
  • TotallyMetal
Posted January 23, 2007 - 07:12 PM
Dude,
You know those all in one screwdrivers that have the small phillips and the straight blade, the other end has a regular #2 phillips and a larger straight blade, then if you pull the bit out you have a driver for 5/16 and 1/4. Following?
I know sounds a bit confusing. I think they call them 6 in 1 screwdrivers... Anyway I use to carry around the small side bit. Now I have an aftermarket one. :lol:
I also tried a thin wall vacuum tube and glued it to the screw, it worked for awhile:excuseme: .
  • Baron Von Beard
Posted January 23, 2007 - 07:29 PM
He's being a smart ass. He knows damn wel how to do it. :lol:
  • Fastest1
Posted January 23, 2007 - 07:31 PM
Dude,
Brass tubing tapped onto the fuel screw as an extension and then either bent over or a roll pin inserted thru a hole for turning and reference. Any small slot screwdriver tip will work but that engine is hot!
  • black_n_blue_thumper
Posted January 23, 2007 - 09:09 PM
$7000.00 for a new bike. $20.00 for a fuel screw to make it run good. Put it in and then take it out when you sell and put it in your new bike. :lol:
  • Ga426owner
Posted January 24, 2007 - 06:16 AM
The reality is it will never run properly until the screw is adjusted correctly...this kid is 18...give him a break. Go buy a zipty or other brand if you want to do it properly....10-20 bucks...and you can take it with you when you sell.....otherwise is is a real pain in the butt to do any other way and temp changes will cause you to readjust......:ride:
  • yz_for_me
Posted January 24, 2007 - 07:33 AM
The best way: an after market fuel screw - or home made equivalent
The second best way: A very short screwdriver. You can get them at harbor freight for like $2.
The best way is about a thousand times easier then the second best way.
  • WFOracer
Posted January 24, 2007 - 08:29 AM
Something like this works great! You can usually buy something similar at Sears.
http://www.motionpro.../fcr_carb_tool/
Two different meanings!
  • stock510
Posted January 24, 2007 - 05:00 PM
Heres a good how to
http://www.thumperta...ight=fuel screw
  • live4speed
Posted January 25, 2007 - 09:08 AM
i adjusted mine by taking an ice pick out of a leatherman tool to turn the screw, and i used a broken cd for visuals...do what ya got with what ya got!lol
  • theclone
Posted February 04, 2007 - 04:22 PM
Ok thanks for the help everyone.
oh and I didn't mean to sound like a smartass, just asking a sincere (maybe stupid) question. I just planned on adjusting it with a screwdriver once, and getting rid of the bike. But now that it looks like no one wants to buy my bike I think I'll just go out and buy a fuel screw. 20 bucks may not be a lot to some of you, but I guess I'm just cheap. :ride:
  • tammie
Posted February 05, 2007 - 06:18 AM
you know those small screw drivers that you fix ur glasses with, they come in a case and there is various sizes i used a larger one and hacksawed it down so it would fix under the carb works perfect .....
  • mnm567
Posted February 09, 2007 - 05:22 PM
You have heard it a hundred times, but buy the aftermarket fuel screw, any kind will work. I will also suggest to buy a tach & hour meter combo so you can precisely adjust the screw and keep track of how many hours are on you bike for maintenance reasons. A properly adjusted fuel screw could mean the difference between life and death when it comes to a tight rhythm section.
Matt
  • Crabtree426
Posted February 10, 2007 - 04:30 PM
I feel you brother. $20 is harder to come by when you're 18. I remember those days. In ten years, you won't think twice about spending $20 or even more in my case. Good luck. :censored:
  • gonzo
Posted February 11, 2007 - 05:53 AM
I've never had good luck with the aftermarket ones. I bought the motion pro tool and I use the bit from the tool and a 9mm 1/4" socket. Works great, also works well for changing the pilot jet without rotating the carb.
Posted February 11, 2007 - 06:56 AM
What's that about? I've never had a problem with one.
  • King_Air
Posted February 11, 2007 - 03:30 PM
Yes Gonzo please let us know what problems you had. I am in the market for one myself and am trying to decide which brand to purchase. I am riding a 00 426.
P.S. I just finished the auto decomp. cam mod yesterday. Boy am I glad I finally did that!
  • 5 replies
  • Hot  36 replies
  • Hot  50 replies
  • Hot  30 replies
