Difference between XR600 & Xr650L
6 replies to this topic
  • danbart
Posted January 23, 2007 - 11:34 AM
Hi guys,
What are the major differences bewtween the venerable xr600 & the trusty XR65L?
What does it take to turn an L into a XR600?
Thanks, Dan
  • cleonard
Posted January 23, 2007 - 02:35 PM
To start with the 650L has a larger piston, but lower compression. The L weighs about 45 pounds more. Most of that weight is in the battery and the starter motor. Other that the engines are very close to the same. The suspension is very close as well. The L has a much larger stator output stock. The L's CDI is driven by the battery and the 600R is a magneto ignition. The transmission ratios are a little different. So is the final drive gearing.
Want to make an L into a R? Dump the extra weight. However that means dropping the electric start.
  • trxxr
Posted January 23, 2007 - 03:01 PM
I thought the L had the same size (dia.) piston just a longer stroke? Plus no kick start on the L.
  • XR650L_Dave
Posted January 23, 2007 - 03:12 PM
The L has a larger gap between 1 and 2, and I think a slightly diff. primary reduction ratio? Or is that the same?
Milder cam, as well.
Dave
  • cleonard
Posted January 23, 2007 - 03:15 PM
I think that the R is 97mm x 80mm and the L is 100mm x 82mm.
  • zodran
Posted January 23, 2007 - 05:18 PM
Yep, the 600 also has a slightly higher compression ratio at 9:1 vs 8.3:1 for an L.
  • motomonte
Posted January 23, 2007 - 05:30 PM
I know this may have been discused before but can anyone tell me how the HP and torque figures of both bikes compare?
